I have the Xerox XC830 copier. Copies are very dark and smudgy. I cannot find the transfer corotron cleaner to insert into the corotron itself.
  • 92 Answers
Thats not it ur mirrors are dirty or u need a drum unit
Posted on Jun 28, 2009
Xerox 7655 the colour magenta is printing light
First, use the charge corotron cleaner a couple of times. If that doesn't improve it, then try swapping the magenta drum with the drum of another color and printing and see what happens. If the magenta is better, but the other color worse, you need to replace the drum. If it is not, you may need to change the charge corotron.
Nov 18, 2015 | Xerox Office Equipment & Supplies
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Does the Corotron Assembly Kit for the XD100 contain the Corotron Wire as part of the assembly kit?
Yes it does:
PL 7.3 TRANSFER/DETACK
COROTRON ASSEMBLY
Item Part Description
1 - DETACK COROTRON
2 - GUIDE
3 - INSULATOR
4 - FRONT GUIDE
5 - SCREW (3X6)
6 - CONTACT COVER (R)
7 - TENSION SPRING
8 600K15950 TRANSFER COROTRON WIRE
9 - SPRING BRACKET
10 - TRANSFER COROTRON SPRING
11 - BC SPRING
12 - GROUNDING SPRING
13 - CONTACT COVER (F)
14 - COROTRON HOUSING
15 - PLATE
16 - GROUNDING PLATE
17 19N415 TRANSFER/DETACK COROTRON
ASSEMBLY (REP 9.2)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
My copies come out with shades on the edge like black lines. what could be the cause
Well you didn't specify the machine model number in your question or title, but that is usually done by the corotron unit being dirty, or possibly the drum unit not cleaning correctly. One other possibility would be the settings for dark/light.
If the problem is with copies from the glass, from the feeder (ADF) from the top, and with printing, then its one of the first two. If it's just from the ADF, clean the small glass ****.
Nov 27, 2009 | Xerox CopyCentre C118 Copier
My Xerox XC830 copies are dark and have lines but otherwise present the image. How can I make the background white again.? Thanks! Ron
You probably needs some servicing. Drum, developer and other parts have a life cycle and once it's exceeded you can start having copy quality issues. Unfortunately there is no easy fix.
Jul 03, 2009 | Xerox Office Equipment & Supplies
Dark background copies and has previous document info also
More than likely the heat roller is bad causing ghost printing.
Apr 01, 2009 | Xerox Office Equipment & Supplies
Replaced toner is printing very light.
If the print quality is the same as the old one - light laser is dirty and/or transfer roller. Fuser would NEVER cause light copies -but rather, dark, smudgy copies
Jan 26, 2009 | HP LaserJet 4 plus Printer
Posted the original problem as Blurry Copies for the Xerox WorkCentre X2424. Did what was suggested which was to clean the encoder with alcohol which is located in the drive/drum motor. Now the unit is...
Have u tried the any of the following?
Clean the Charge Scorotron and the Transfer Corotron
Unlatch Then Relatch the Transfer Unit Below the Xerographic Module
Remove Paper and Other Obstructions From the Paper Path
Use Paper or Other Stock From a Fresh, Unopened ****
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Black stripe on copies
Please be more specific.
Are the lines appearing in the direction the paper exits the machine, or from the front of the paper to the rear?
Jan 09, 2008 | Office Equipment & Supplies
Xerox xc830
try cleaning the optics under the glass.
Jun 20, 2007 | Xerox 8830 Copier
283 people viewed this question
k24674
