Question about Humidifiers
I need the water tank for a 40 cm Moretti misting fan
The water tank has cracked and I want to find a replacement tank
3 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Posted on Jan 20, 2008
  • 114 Answers
SOURCE: I dropped the tank. Whre can I get a new tank?
you can check any hardware store or if you live in canada you can check with canadian tire.
Posted on Aug 29, 2009
Water leaking from tank cap HM495
is the rubber seal in place on the cap or did you lose it could be a small crack where the threads are look for both , good luck
Mar 07, 2015 | Humidifiers
Won't blow mist out
I have a similar problem. I found a crack in the tank. I am trying to find out if it is cheaper to replace the tank, or just buy another one. I have tried other types and like this one the best.
Dec 22, 2012 | Walgreens Cool Mist Humidifier, 1 ea
Why does my humidifier make the floor all wet
You may be over filling the unit. Take the refillable water tank out and with the power removed try to remove all the extra water where the tank goes. check for anything that looks cracked inside the unit the best you can. If the tank is seating properly it should not leak. If it is filled properly it should not leak.
Mar 22, 2012 | Vicks Humidifiers
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
Mar 20, 2009 | Bionaire Humidifier BCM657U Humidifier
HCM 640bw leaks
Look for a microscopic crack in the water chamber. Leaking air will allow the water to continue to drain out of the tank. A bit of glue and duct tape over the crack should fix it.
Dec 11, 2008 | Honeywell QuietCare HCM-630 Humidifier
Need to find a new water tank
Mine also cracked along the seam several years ago. I sealed the crack using two-part waterproof plastic epoxy (found at any hardware store.) Not really pretty to look at, but it hasn't leaked since!
Dec 01, 2008 | Holmes Products Cool Mist HM3500...
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
A:
Owners manual LINK
OK?
A:
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Humidifiers Logo
338 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
