Question about U-Line Refrigerator Ice Maker
Clean/reset light comes on 2 days after cleaning
I cleaned the ice maker with the correct (expensive) cleaning solution. Then 2 days later the clean/reset light comes back on. I tried holding the reset button, nothing changed,
  • peyton thompson
    peyton thompson May 11, 2010
    Can you get me a model and serial number for this unit. I would like to look it up so i can see exactly which model you have for a correct solution. peyton
I need box type relay wiring
Posted on Feb 16, 2009
Icemaker will not restart
1 Lower the bail wire to turn on the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Apr 10, 2015 | Refrigerators
MY ICE MACHINE MV 600 DOESNT FORMULATE ICE BUT THE WATER IN THE PAN IS COLD
its either iced up {the wee radiator in it } of the fan has failed that blasts cold air leave it all open for three days and clean it then try again
dont forget to clean the pipes to any evaporator etc.. thats fitted
it may not be detecting cycles so power the whole lot off and reset it can be the only way after a good deep defrost and total clean ,,,
Dec 27, 2014 | Kitchen Appliances - Others
How do I clear a yellow light on my Scotsman ice maker?
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Dec 02, 2014 | Kitchen Appliances - Others
Scotsman ice maker, short freeze code no ice
this Scotsman Prodigy had bad Ice thickness probe, error was for long freeze cycle. Hope this video will help someone
Jul 13, 2014 | Kitchen Appliances - Others
My ice maker just have freeze one side
Check the Freon again. Sounds like it is leaking out.
Dec 23, 2011 | Hoshizaki KM-630M Crescent Cuber Ice Maker
Cleaned ice machine because desale light was on , unit is cleaned and run through clean cycle buy desale light still on
make sure you press the clean button let run 10 min or so then press it again.if you dont press it the second time descale will not reset.
Aug 06, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
It is getting increasingly difficult to clean the coffeemaker when the clean light comes on. vinegar doesn't touch it. This morning I used a whole bottle of CLR over 5 attempts which finally got the...
This is my solution and so far it's worked great. I use "Dip It" coffee maker cleaner, following the instructions on the dip it bottle. I use the clean cycle and run the 5 cups of water and 1/2 bottle of dip it. Once it runs through, I run two cycles of clean cold water. I unplug the coffee maker and let it sit over night. I get up, reset my clock and "presto" the light doesn't come on. I run 2-3 pots of coffee daily so I end up cleaning it as soon as the light comes on haven't had any problems since I started doing my cleaning this way. Before that, I was about to scream! I hope this works for you.
Nov 27, 2010 | Cuisinart DCC-1200 Coffee Maker
The ice maker just stopped making ice.
First , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve ( pt. # 4389177 ) . If it does not dump the cubes , replace the ice maker ( pt. # 4317943 ) . After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Dec 04, 2009 | Whirlpool ED2FHEXN Side by Side...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
U-Line Refrigerator Ice Maker Logo
119 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
