Question about Whirlpool Washing Machines
Whirlpool Model LA7680T Washer. The bottom unit works but the top half does not. Is it an easy fix or do I need another Washer
The bottom part of the agitator will draw the clothes down and they do circulate but without the top half of the agitator working I don't believe the clothes are getting as clean as they should be.
SOURCE: Maytag Performa Large Capacity Top-load Washer
Krazytech, Just because your solution didn't work for me does not mean it won't be helpful to someone else who reads it. It was just not helpful to ME...but thanks for the personal attack. You may be a "Master" at technical questions, but you fail miserbly at customer relations. By the way, some people need help with THEIR spelling before posting THEIR negative replies.
Posted on Sep 17, 2007
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
  • 1073 Answers
SOURCE: Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
Posted on Apr 16, 2008
WRMtech
  • 70 Answers
SOURCE: top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Posted on Feb 26, 2009
Macmarkus
  • 2605 Answers
SOURCE: top half of agitator not working bottom part is
Hi, I'd suspect the agitator gears (dogs) are worn. You'll need to remove the top of the agitator, (the cap) and then the 9/16" or 1/2" bolt in the center...it may look nothing like a bolt, it may be a plastic block, but it still screws off counter-clockwise. Once you have the agitator unfastened, you'll expose the hub/retainer which hold's the gears in place. Now you need to install new dogs alone part # 80040 or what I'd recommend, part # 285751 as a kit with new hub too. These are common and availble at most brick & mortar parts depot's as well as on-line vendor's such as "repairclininc.com" or "searspartsdirect.com". Hope that help's, let me know if I can assist you further. Thank's for visitng "fixya" today. Please take a second to rate this solution & leave a testimony. Good luck, macmarkus :)
Posted on Jul 27, 2010
Need to know capacity for a Whirlpool washer with model number E113C68PXCAP4580
Its pretty easy to calculate. open the top and place a straight edge across the top of the washer, then measure the height in inches from the bottom of the tub to the bottom of the straightedge. Next measure the inner distance from one edge of the tub to the other and cut that number in half. For example: Say the height is 30 inches and the distance across is 28 inches (cut this number in half so use 14). The total cubic inch volume would be calculated like this:
V = 3.1416 x (14 x 14) x 30
3.1416 x 196 x 30
18472.61 cubic inches
Divide 18472.61 by 1728 giving a capacity (volume) of 10.69 cubic feet.
Mar 02, 2015 | Whirlpool Washing Machines
Kenmore elite oasis washer model 110
the top half comes off --- the dog ears that ratchet the top are gone. There is a replacement kit to fix it --- About $30 You need to pull off the top of the agitator and use a long driver and socket to take off the nut you can see inside the unit. It is an easy fix. Just go to the appliance parts store and get the replacement part. You can wash your clothes without it working but it has to be a small load until you fix it
Jan 08, 2014 | Washing Machines
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Need to replace the agitator dogs and can't remove the mover from the bottom section
    Direct drive Whirlpool washing machines use a two piece agitator. In-between the two pieces there are cogs, sometimes referred to as "dogs," which will wear out. When the dogs start to wear, you will notice a clicking sound and the top agitator will not move as it should. When you learn how to replace the agitator dogs on a Whirlpool washing machine, you can have your Whirlpool working correctly again. Agitator dogs are available at appliance repair facilities.
    * 1
    Disconnect the Whirlpool washer from the wall outlet. Open the washer lid to access the agitator.
    * 2
    Insert a flathead screwdriver in the notch in the agitator cap. Twist the screwdriver to pop the agitator cap off of the agitator. If your model has an inner cap, remove the inner cap by pulling up on the handle and removing it from the agitator.
    * 3
    Use a socket wrench to remove the bolt in the center of the agitator. Most Whirlpool washers use a 7/16-inch bolt to secure the agitator.
    * 4
    Grab the bottom of the agitator with both hands and pull it straight up out of the wash tub. Do not have your face directly over the agitator. If it is stuck or pops up too quickly you could injure yourself.
    * 5
    Set the agitator on the floor and carefully place your feet on each side of the agitator. Grasp the top of the agitator and pull the top half of the agitator off of the bottom half. Turn the top half over to access the dogs.
    * 6
    Use needle nose pliers to pull the dogs out of the agitator. Install the replacement dogs into the agitator according to the specifications given the manufacturer.
    * 7
    Set the top half of the agitator back on to the bottom half. Make sure to align the two tabs together between the halves so that they will friction fit. Grab the bottom of the agitator and apply a thin coat of dishwashing detergent on the rubber gasket on the bottom using your finger.
    * 8
    Set the agitator back into the wash tub and secure it using the retaining bolt. If your model had an inner cap, set the inner cap back into the agitator until it snaps into place.
    * 9
    Place the top of the agitator into place and press down until it locks into place.
    Mar 21, 2011 | Whirlpool Washing Machines
    Ultimate Care 2 Washer, Bottom half of agitator not turning
    The problem is simple and inexpensive to fix. The agitator dogs are worn and need to be replaced. The following link explains:
    http://www.fixya.com/support/r823955-replacing_agitator_dogs
    Read through the instructions and let me know if you have any questions. Use the part number provided for ordering any replacement parts. I hope this helps you.
    Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool top loader washer not agitating
    Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
    Vic
    Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer doesn't spin.
    Hi, sounds like you need a motor coupler.
    Dec 28, 2008 | Whirlpool LSR5132PQ Top Load Washer
    Won't agitate!
    does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
    Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
    Whirlpool GHW 9400P
    Hello! your problem is the motor control unit,MCU.
    or the central control unit,CCU. Try unplugging the washer for a few minutes sometimes that will reset the unit.There is a tech sheet inside bottom of the washer cabinet.If youre not sure, may need a service tech.
    Dec 17, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
    Washing Machines Logo
    65 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
