Question about IBM ThinkPad T43 Notebook
Missing drivers? IBM thinkpad T43. reinstalled windows XP and now I have exclamation marks on Device manager for the following: Biometeric coprocessor multimedia audio controller pci modem I have system sounds, but no other sounds
  • mhisham212 Jan 28, 2009
    yes
  • David Hilow May 30, 2013
    All you need to do with that is get the drivers for the system off online. Drivers are what makes the sound system work on the operating system.
    Sergeant:
    Champion:
  • 318 Answers
Go to this link and download drivers.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-58597&velxr-layout=print
Posted on Jan 19, 2009
I have no sound in it no sound driver
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
if your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers
rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
note: it will find all of your outdated drivers
this is a free driver solutions
which will automatically search for and find the correct driver
it might take some time being free
also
http://download.cnet.com/2000-20_4.html
just type in what you want or need be specific you might have to try a few times to get it right
IE: motherboard name sound drivers
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
hope it helps
Aug 16, 2012 | Lenovo IBM ThinkPad T43 Notebook PC -...
I need a sound driver
if your computer came with a motherboard disc the sound drivers could be on it
also
hope it helps
Jul 11, 2012 | IBM ThinkPad T43 Notebook
When i reinstall my window it seem that the sound went missing
You can try going to IBM's site and downloading multiple sound card drivers for other models within 2 years of yours. They miss and match devices alot like Dell and HP does. Extract the drivers in seperate folders on your desktop and point the browse to one folder at a time until you kind the correct driver. I believe IBM will take your call free for issues like these even out of warrenty period.
Dec 29, 2009 | IBM ThinkPad T43 Notebook
Have reformatted the thinkpad t43 with windows xp. wireless adapter not visible in hardware devices. Help!
have you installed all the device driver for the hardware of the notebook? if not run all the device software including the driver for the wireless adapter, it will not appear if it is not windows compliant you have to provide the drivers
Nov 24, 2009 | IBM ThinkPad T43 Notebook
IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Oct 07, 2009 | IBM ThinkPad R30 2656 Notebook
No Sound on my IBM t43 Thinkpad
all hardware requires a driver
driver is an information file that tells the operating system how device works
without the driver the device cant work
when you reformatted you must not have installed sound drivers
here is a link to Windows XP version of the sound drivers of your laptop
http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/1ya210ww.exe
download it
install it
reboot
and you will have sound
if you have a different operating system than windows XP, tell me and i will give you link for that
Sep 30, 2009 | IBM ThinkPad T43 Notebook
XP Drivers for IBM ThinkPad x41
FOR WINDOW DRIVER: WWW.WINDRIVERS.COM
WWW.MRDRIVERS.COM
WWW.MOTHERBOARDS.ORG/DRIVERS
WWW.IBM.COM/THINKPADX41
WWW.MICROSOFT.COM/DRIVERS IBM THINKPAD X41
ENTER
TYPE IN THE ADDRESS BAR:
WINDOWS XP DRIVERS FOR IBM THINKPAD X41
ENTER KEY
CNANDYMANGANDY
Feb 13, 2009 | IBM ThinkPad X41 Tablet PC
No sound
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Sep 11, 2008 | IBM ThinkPad R50e Notebook
Same problem, wireless does not work after reinstalling windows (thinkpad t43)
This is generally a simple driver glitch. Uninstall the wireless drivers from the device manager, then reboot. The machine will find the wireless and reinstall the drivers.
Jul 17, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
686 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
