Connect dlink dir-826L to 3ds - Computers & Internet
jkhtkd
  • 4 Answers
SOURCE: DLink DIR-615 can forward ports
You probably have a 3rd part firewall software on the PC, configure that firewall to allow the same ports. what AntiVirus do you have?
Posted on Jan 29, 2009
SOURCE: VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Posted on Mar 17, 2009
niquose
  • 198 Answers
SOURCE: Dlink DIR-625 permanently stopped
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Posted on Jun 26, 2009
  • 10 Answers
SOURCE: sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Posted on Sep 13, 2009
Testimonial: "tanks v. much for answer, i'll try it right away"
govinda123
  • 2263 Answers
SOURCE: dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Posted on Jan 12, 2010
My dlink is not connecting.
Have you reset the D-Link to default setting, and reconfigure the SSID and the Security Key? Perhaps this will help: http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20835/Manual/DIR-835_Manual_US.pdf
Apr 19, 2013 | D-Link Dir-835 Wireless N750 Db Router...
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
Dlink dir-142 Dodo usb prepaid dongle t12146l140 no connectivity optus usb prepaid dongle e169 responsive, no internet coverage connects with nintendo 3ds but no internet connection. windows xp...
plug the usb modem into usb slot of pc as normal.
Bridge the connection between the internet connection and ethernet router connection in network page.
Set router to ip add etc and it should share net access while pc is turned on atleast.
Jun 14, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
Need software for dlink dir 301 wireless router
Here is the link to the manual for your router. Follow it's instrunctions to login into the router and from there you can run the setup wizard. If you feel comfortable in doing so, you can set the wireless configuration manually. Please reply if you need specific assistance.
http://74.125.93.104/search?q=cache:FT1VlyIdfuUJ:ftp://ftp.dlink.co.uk/dir_products/dir-301/DIR-301_Manual_English.pdf+dlink+dir+301&cd=5&hl=en&ct=clnk&gl=us
Good luck and thanks for using FixYa!
Apr 09, 2009 | Computers & Internet
Cannot connect to Xbox360 live with Dlink Router
try opening the ports on your router go here to find out how to do it
http://www.portforward.com/english/routers/port_forwarding/Dlink/DIR-300/DIR-300index.htm
Apr 04, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Can't connect to my K-jam to my new DLink DIR-655 wifi router
Can't connect to my K-jam to my new DLink DIR-655...
Mar 11, 2009 | i-mate K-JAM Cellular Phone
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
