Prima LC-3227P no picture or sound some vertical lines
4 Suggested Answers
ProMonkey
  • 59 Answers
SOURCE: no picture vertical colored lines blinking
im afraid to say your display has gone contact funai they should be able to help you replace the display.
Posted on Mar 10, 2009
satavlad
  • 405 Answers
SOURCE: Aquos LC-37D40U has vertical blue lines spaced about an inch
LCD panel replacement required, not economical.
Posted on Oct 24, 2009
  • 252 Answers
SOURCE: i have a sharp lcd
The reason that you are getting these vertical lines on your screen is bcause your horizontal output chip is bad. If you have electronic experience please replace it. If you do not please dont attempt to do this call a tech because you can end up doing more damage to your TV
Posted on Sep 02, 2010
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
I have a prima lc 37r25 have power but no sound or pic need help
Horizontal output section to your TV has the fault. Line Output Transformer should be suspected.
Apr 28, 2012 | Televison & Video
I have a 15 inch Advent LCD TV in my kitchen. I turned it on today and have no picture. When I switch stations I get a picture for a minute then it is replaced with vertical lines or a blank screen with...
U have vertical lines for a few second.That mean u tv have a dead board call the T-CON decoders is board.This T-CON decoders board sit at the bottom wright in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Dec 11, 2010 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
My prima tv turns on but no image and no sound
maybe the problem is in vertical section try to replace the vertical ic and try to measure the voltage.
Sep 16, 2009 | Prima C2012 TV
Problem with tv
The problem is sometimes caused by the vertical output integrated circuit (IC) failing, but usually it's bad solder connections. If you or someone you know is comfortable with electronic soldering, a few minutes spent resoldering the IC pins to the circuit board will often solve the problem. Failure of these connections is common because the IC gets quite hot (and it's mounted on a metal heat sink). The heating and cooling cycles cause the solder joints on the circuit board to crack. You can usually see the trouble with light and a magnifying glass; gray grainy joints instead of shiny connections, and often visible ring cracks around the pins.
Mar 31, 2009 | Konka K1938U 19" TV
Prima 27in. hd flat screen
50% trouble of tv is lose connection,first thing you will do is to re solder your tv. must specially the vertical section and the jungle
Oct 29, 2008 | Prima CV2011 TV
My HT3061P Prima tv, has the black screen, but the audio is very good.
adjust first the screen. it is a knob at the back of plyback.(lower knob),if the has vertical line ,then the section had a problem.try to resolder the vertical IC or else change the IC.
Oct 15, 2008 | Prima CV2011 TV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
