Question about Sharp EL-1801P Calculator
How do I get the paper to feed into the back
I am trying to refill my roll of paper and cannot get the paper to feed
  • mcaughey Feb 09, 2009
    I can't get a new roll of paper in this EL 1801V calculator.
  • 4 Answers
It helps to fold over the edge of the new paper so it's easy to insert far enough in to catch.
Posted on Feb 03, 2009
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you load the paper on this adding machine?
      • 1 Cut the beginning of the roll of paper at a 45-degree angle with the scissors for better feeding into the Canon P23-DH V.
      • 2 Lift the paper arm up and slide the roll onto the paper arm. The cut edge of the paper should be feeding down from the outside of the roll.
      • 3 Insert the cut edge of the paper into the small **** at the back of the calculator.
      • 4 Press the feed button in the upper left area of the calculator's keyboard to feed the paper roll up through the calculator.
    Jan 30, 2011 | Canon P23-DHV Calculator
    How do I install adding machine paper roll
    Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
    If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
    If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
    Nov 23, 2009 | Canon P1-DHV Calculator
    How do you load the paper?
    Aug 31, 2009 | Canon P23-DH Calculator
    Need help replacing the paper roll on a Casio BIG 12-Digit adding machine.
    Aug 21, 2009 | Office Equipment & Supplies
    Cannot load new paper roll into the calculator so it catches
    Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
    When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
    To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
    Then, slide the paper roll onto the feeder arm and you're in business.
    Apr 09, 2009 | Sharp EL-1801C Calculator
    Putting new paper roll in
    It's difficult to see, but the feeder for the paper is on the back of the machine, just below where the roll of paper goes. You'll see a little slot above the opening for the batteries. Feed the paper in here and push the arrow up button above the ON/C button to get the paper feeding through the mechanism. It should pop out at the top!
    Jul 29, 2008 | Canon P200-DHIII Calculator
    Paper feed rolls is rolling over the paper...how to get access to those rolls
    1. Feed the paper manually into the printer:
      1. Place a sheet of plain A4 paper in the paper feed tray.
      2. Move the paper support on the left-hand side to the left end of the paper.
      3. Press the paper feed button.
      4. If the paper does not feed, continue with step 2.
    2. Check for any obstructions in the paper feed path:
      1. Disconnect the cables from the back of the printer.
      2. Open the front of the printer and check for anything that may be blocking the paper path.
      3. Close the front lid and remove any paper from the paper feed tray.
      4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
    You can clean with special cleaning paper which ca be used clean the rollers............
    Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
    Changing paper roll on Citizen CX-121 Calculator
    At the back between the top cover and bottom cover is a tiny groove to slip the paper in. Simple if you know how. I need a manual please.
    Dec 04, 2007 | Office Equipment & Supplies
    Sharp EL-1801P Calculator Logo
    408 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
