Question about GE Refrigerators
I looking for a door seal part number GE TFG20JRXA
3 Suggested Answers
Techsim
  • 59 Answers
SOURCE: GE Profile Door Seal
There is a cam at the top of both doors the grab on to the fridge to hold the door s shut. There has been a problem with them breaking and not holding tight. Check the door and make sure the cam is gripping the cabinet correctly.
Posted on Nov 02, 2008
EllaWatson25
  • 725 Answers
SOURCE: door seals are in need of replacement
We have all types of parts and accessories for your Amana refrigerator. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with the Amana model number that you posted on this blog and we will get the correct seals out to you asap.
You can call us from 7 AM until 9 PM CST so call when you are ready to repair this unit.
We look forward to working with you. Thanks, Ella
Posted on Nov 13, 2009
We purchased a used GE gas range with sealed burners and self cleaning oven. We are trying to find the model and serial numbers for it. They only numbers we can find are inside the oven door on the side...
How to find the MODEL NUMBER
  • Look for a silver or white label as shown in the drawing below
  • Zeros and ones often look like the letter "O" or lower case "L"
  • Model numbers from owner's manuals are often incomplete or incorrect
Sep 28, 2010 | GE Kitchen Ranges
Can the water pipe in a GE SBS door be replaced?
Hi and welcome to FixYa. I am Kelly.
Open the door and then lift
gently the door seal from the inside. You will note that there are screws in the door. All you have to do to open the door is remove all of the screws for the door gasket and possibly a fet bor for the mteal retaining place for the door seal. The door will come apart but is is a tedious process to get it back together if you do not lay it flat. Sometimes you get lucky but if there are 2 people then you can do it door on. The water line is replaceable but usually you need to know how long of a water line that you need as it is sold in bulk by the foot. It appears that there is a hose just at the hinge point that can be purchased separately.
Take a look at this link for the Location of the hose here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5209032&diagram_id=22190124#d22190124
It looks like item 80 that your talking about.
Just take your time and do not get in a hurry. Things have a tendancy to break.... (lots of experience on my part!)
Thanks for using Fixya.
Kelly
Jun 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
I need to change the door seal on a 1990 ge fridge and top freezer, looking for tips on how to remove and replace seal. i have the new seal.
place new seal in warm water for 15 min. start at one corner, remove appr 4 srcews in each direction pull old gasket down. now start to install new. continue to remove old and install new. make sure to remove weight from door. after your done place a film of vasoline on mating surface.i sometimes will roll a small amount of paper towel to insert where gasket is not wanting to pull up . push door firmly shut for a few days.
Jan 19, 2010 | GE GTS18HCM Top Freezer Refrigerator
Door seals are in need of replacement i dont have the part number for the seals. this is a GE refrigerator 23Z
Nov 13, 2009 | Amana ABB1921DE Bottom Freezer...
R door- GE 21.6 is slipped down. Gasket cant seal, part needed?
the parts detective dot com has all sorts of repair parts. You'll need the model and possible the serial number.
Aug 11, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Oct 31, 2008 | GE Profile PFS22 33" Artica French Door...
Door seal on GE Adora Washing Machine
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
Jul 21, 2008 | GE WSXH208A Front Load Washer
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
