Question about Sewing Machines
My basic singer 5932 machine that I've had for about 11yrs is acting up on me....Never had a porblem til today. Probably an easy one for you experienced sewers. The thread underneath is very loose and bulking up. Initially the tension was too tight, thats ok now. How do I tighten up the bobbing thread or the under sewing thread?? Thank you in advance, Nicole
  • arty556 May 09, 2009
    I need step three as I have tried 1 and 2 and still have thread looping on the bottom of fabric. Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Also look at:
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Posted on Mar 18, 2009
I have a model 5932 the thread bunches up about 2 inches under the bottom of the fabric
Posted on Oct 18, 2010
My singer 5932 auto bobbin winder is not working?
Make sure that something like your buttonhole lever or button for a twin needle are not down (if you have them). You can get it fixed, but you can also just buy a Simplicity bobbin winder for under $25, that actually does a better job anyway.
Aug 18, 2014 | Singer Sewing Machines
Does anyneed a model 5932 singer sewing machine
I don't know if you have found someone by now, but you might try listing it in Craig's List, either for a nominal price, or you can list it as a free giveaway. You can also donate it to Goodwill or the Salvation Army.
Jul 13, 2014 | Singer Sewing Machines
How to use the stich pattern on singer model 5932?
Download the instruction manual free from the Singer Sewing Machine site; it's on page 17.
Jun 20, 2014 | Singer Sewing Machines
Singer 5932
Hola tambi?n tengo una m?quina singer modelo 5932 tengo problemas al momento de enebrar la aguja, la m?quina se salta puntadas, el zigzag no lo hace bien y por la parte de atr?s se ve la costura suelta o los hilos enrollados, no se que hacer, no tengo manual y no encuentro nada en YouTube, ni en Google, no se si el problema sea la bobina, la tensi?n (la tengo entre 4 y 5), el enebrado, la aguja o yo!! Jaja ayuda!!! Graaaciasss mi correo es roselix.fernandez@gmail.com
Jan 06, 2014 | Sewing Machines
Need quick directions on proper threading of a singer sewing machine model 5838
You can get frre threading diagrams from www.sewusa.com
I couldn't see instructions for the exact model number you mention.
These are for the Singer 5932, which I assume will be very similer to your machine.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_5932_threading.htm
And these are for the 5508 and 5528
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_5508_5528_threading_diagram.htm
I hope this helps!
Nov 15, 2010 | Singer Sewing Machines
Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
May 11, 2009 | Singer Sewing Machines
Need manual to know how to set tension. Singer Sewing machine Mod.#5932 Serial#N319411147
Singer Machines are probably the easiest to set..
first thing you need to do is remove the thread..
Set you tension knob/wheel to the middle number.
When you rethread the machine, stop when you get to needle. Put the presser foot down and pull the thread. If it pulls hard then so far so good. If it pulls easily, the thread is not thru the tension wheel right. Thread the needle and stitch about 10 inches on a medium wt fabric.
The stitching should feel even on both sides. If the top still is tight, loosen it up just 1/2 number.
So, if your middle number is 4.5, turn it to 4. If it seems loose, turn it to 5.
Kelley
Apr 30, 2009 | Singer Sewing Machines
5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Jan 28, 2009 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
1,038 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
