Question about Fujitsu ScanSnap S510
Having trouble installing ABBYY software for Fujitsu scanner
When trying to run setup that's been downloaded to desktop, I get error message that states "initialization file of the setup program not found. Please contact your system administrator." ...
So, what do I do here? ...
  • 1 more comment
  • seasamh Jan 24, 2009
    I just received my new ScanSnap, and I have the same problem. This is apparently an old version of ABBYY FineReader, and it doesn't appear that ABBYY provides any support with it. Help!
  • RusCon- Feb 04, 2009
    I have the same problem!
  • jchilliard Feb 20, 2009
    me too!
3 Suggested Answers
SOURCE: how to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Posted on Nov 29, 2007
SOURCE: I lost the ABBYY FineReader
You can download the software at this web site:
https://www.pfu.fujitsu.com/registration/ss-setpg/en/no-check01.html
Posted on Jan 04, 2011
I have an IMac with a Fujistsu S1300. I upgraded the harddrive and now the scansnap application does not work. I have tried to re install the scansnap but it always gives the same message" General Error...
There might be a software package that you need to install that you can probably get from the Fujistsu main site. You'll need the drivers for the scanner. I think i've located the correct ones here:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
You'll want to download the proper package. The top one should include the S1300, just make sure you're downloading the correct one. Once downloaded, install, and it should properly function.
Dec 13, 2013 | Fujitsu ScanSnap Manager
I have a Plustek OpticFilm 7600i SE film scanner. Every time I try and load-up the setup disc, the set up install starts and then comes up with this error message: An error (-500 : 0x8004ace8) has...
It is quite possible that there is another piece of software that is clashing with your Plustek OpticFilm scanner. It is hard to tell which software is having a clash. If you remove that software from your system you will obtain the desired results. I suspect the SP3 of Windows XP may be responsible for this because Microsoft has indicated that Windows XP SP3 is not for everyone. If you install Windows XP SP2 uninstalling XP SP3 your problem can definitely be rectified.
Good Luck!
Mar 10, 2011 | Plustek OpticFilm 7200 Film Scanner
Message says generic error
Reinstalling the latest driver for your scanner should correct any software related issues.
You can find the drivers for your scanner here: Drivers V 4.2.2.2
1. Download the driver and save it to a folder on your desktop. You will then need to right-mouse click the file and EXTRACT the installation files. Do not run the installation with the scanner connected.
2. Turn off your computer and disconnect the scanner.
3. Restart your computer with the scanner disconnected and run the scanner installation program found in the folder, usually SETUP.EXE. Follow the prompts. Do not reconnect the scanner until prompted to or the installation ends.
Please be aware that the scanner installation file is 118MB and may take quite a while to download depending on your internet connection.
Happy Scanning, Myridom
Mar 05, 2011 | Plustek OpticBook 3600 Plus Flatbed...
I am having a trail version of abbyy pdf transformer 2.0 so please help me to free download serial no of this
While I cannot help you download a serial number (you have to pay for that), I can suggest a free alternative. PDFedit has the ability to edit PDFs like Abbyy. It is made for UNIX/Linux systems, but if you are running Windows you can install Cygwin first and then install PDFedit within the Cygwin environment.
Mar 03, 2011 | ABBYY Software House PDF Transformer...
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Donot scan in word.exe format
do you have installed abbyy finereader or not if its installed then try to reinstall
if its not installed download it from net and install
May 01, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
Scanner
I have installed Snow Leopard on my Mac and my Snapscan Touch AGFA will not work. This is the message I get on opening -
ScanWise can not find the current ColorSync System Profile. Please recalibrate your monitor or select another system profile with ColorSync Control Panel
Can anyone tell me how to fix it.
Jan 17, 2008 | Office Equipment & Supplies
Fujitsu ScanSnap S510 Logo
301 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
