Question about Westinghouse WTR7000 White-Breadmaker WTR-7000 Instruction Manual Recipes PDF
I dropped my bread machine and cracked the door.
The door cracked from the hinge to the steam vent. It is a fairly sizable crack. Is there a way to fix it? Or get a new door? Is it usable?
    Genius:
  • Westinghouse Master
  • 1,280 Answers
Need make and model # of your bread machine
Posted on Jan 05, 2013
Is there a repair kit or solution to fix the rear windshield line that has cracked in two. It is located inside the door hinge.
No. best the cut the wires on the inside of both body parts and fish threw new line and connect them there. Fixing the break in the hinge part is a pain and doesn't last long.
Oct 07, 2016 | Cars & Trucks
Losing coolant, steam coming out heater vents, checked oil and it isn't milky
You have a crack in the heater core. They are made of plastic. The air to the car comes through the heater core and because the core is cracked you are getting air and steam. The good news is that your head gasket hasn't gone :>)
Mar 20, 2016 | Cars & Trucks
I can only get air from the side vents the control knob moves but dosnt change the air flow direction
Denise; You have a blend door malfunction, cable broke, came off, hinge broke, if motor controlled seized, if vacuum controlled could be hose off or cracked.(I think yours is cable and plastic gear type)
I will post links below of the problem and fix.
PRESS THE HELPFUL BUTTON
How to fix stuck heater control knob EVO Boosted Films
http://www.automotiveforums.com/t945781-discuss03_lancer_heater_control_heater_box_fix.html
Blend Door Or
Feb 06, 2016 | 2002 Mitsubishi Mirage
Broken door on front load washer, Door cracks on side mounted to machine by hinge.. Second door cracked in same spot
Not sure but check with the manufacturer, there may be a recall notice for this problem.
Jan 17, 2015 | Washing Machines
My new composite House door is driving me mad !
were is is cracking from? please post a pic of the door and its hing area. and catch area, this will help determine the problem. and would be able to help more.
Jul 21, 2017 | Audio Players & Recorders
The hinge on my phone cracked. this is the second time. nothing of consequence caused the problem. phone is about 13/14 months old. first time was in warranty. what recourse do i have? phone is still...
the only thing I can suggest is to seal the crack with super glue. and really watch your habbits with the phone. open gently, close gently. user your fingers only to do both of those. keep your phone away from pockets or holsters which may get hit during the course of your day.
Jan 12, 2010 | Motorola Mobility RAZR V3
Leak from dishwasher door
Usually this problem is an easy fix. Try this first.
1.) clean the rubber seal that goes around the door and the knife edge on the unit with a dish rag to remove any dirt. Also check for cracks and dents as you go. If you find a crack in the rubber ... replace .
If you find a crack in the plastic knife edge of the unit, you will have to epoxy it and sand smooth (carefully)
2.) OK, if that didn't help ...on mine, there is a steam release vent. On the outside of the door is a vent that releases steam from the hot water. On the inside of the door is a removable water trap that might be full of old gunky stuff. Clean that stuff out of there.
WHEN MY UNIT WAS LEAKING WATER IT WAS #2
Let me know if you need more help.
Best of Luck,
RSMITH972278
Oct 13, 2009 | Neff 24 in. S5456 Built-in Dishwasher
How to replace the whole door unit
This should be a fairly simple procedure. To replace most microwave oven doors, all you have to do is open the door as wide as it will open and then lift straight up. The door will come off the hinge mounting pins and lift off. Install the new door by holding it in the open position and aligning it properly on the hinge pins. NOTE: On some models, you may have to remove the upper trim above the door. I hope this helps you. Let me know if you have further questions.
Jan 03, 2009 | Maytag MMV5000 Microwave Oven
Driver side visor
its better to just buy a new one from the dealership. or a junk yard. but junk yard part might break again. heres the part number for the visor fe01-69-320e-77. its an updated part so itll hold and last longer than the original one in there.
Jul 17, 2008 | 2004 Mazda RX-8
Freezer door opens just a tiny bit when i shut the fridge side anybody know how to fix this
to be honest with you, close the door more gently. there are air vents between the frig and the freezer, when you close the frig door its forcing air into the freezer which in turn forces the door open some. the air has to get out so thats what it does. i hear this complaint alot.
Nov 27, 2007 | Frigidaire FRS3R5EMB Side by Side...
Westinghouse WTR7000 White-Breadmaker WTR-7000 Instruction Manual Recipes PDF Logo
44 people viewed this question
Top Westinghouse Kitchen Appliances - Others Experts
Irene Tulloch
Tom Chichester
Are you a Westinghouse Kitchen Appliances - Other Expert? Answer questions, earn points and help others
