Question about Dell Inspiron 6000 Notebook
Sporadic Booting Hi I have a problem switching on my Inspiron 4000. I have to push the power switch repeatedly and with a certain interval after the last attempt (a matter of seconds) before I can persuade the laptop to spring into life. In short, there seems to be a "knack", which can be very frustrating. I'm running Windows XP but the machine only has 256MB RAM. Grateful for any suggestions. Cheers John
  • elevatordrop Jan 19, 2009
    Thanks Dageezer, all the lights (3 by the power switch, 3 on the right) come on briefly (which would tend to suggest that the switch is doing its job) , but there is no "whirring" or booting/ disc spinning noises. The battery has no more juice but I'm plugged in directly. Removing the battery altogether has the same effect... Could it be a RAM connection problem?
  • 3,940 Answers
Depending on whether the issue is powering on, or booting to the OS, will determine the failure in the system. If the system powers on but will not boot to the hard drive, then the answer may be the HDD is slow to spin up to operating speed. If this is the case, then multiple attempts to start the computer will spin up the drive but it will not stop spining before the next attempt. After several tries, the HDD gets to operating speed fast enough and boots.
If the system is not powering on at all, then I suspect a problem in the switch itself/motherboard.
Posted on Jan 19, 2009
92 crown vic lx ... I changed the wiper motor, switch and the power train Control module. Still don't have wipers!! Any suggestiobs??? Thank you!
1. Access the interval governor located above the warning chime
under the driver side of the dash and disconnect it.
2. Install a jumper wire between the Dark Green (DG) wire and the Yellow/Red (Y/R) wire.
3. Install a 2nd jumper wire between the Dark Blue/Orange (DB/O) wire and a Black (BK) wire. Either BK wire of the module should work, both are dedicated chassis grounds for the module.
4. Turn the ignition switch to the Run position and verify that the wipers are running on low speed.
5. Disconnect the jumper wires.
6. Connect an ohmmeter between the Dark Blue/White (DB/W) wire and the Brown/White (BR/W) wire.
With the wiper switch in the OFF position, resistance should indicate about 47,500 ohms.
7. Move the wiper switch to the low speed position, resistance should change to indicate about 4000 ohms.
8. Move the switch to the high speed position, resistance should change to indicate less than 100 ohms.
9. If the wiper motor runs and the switch resistance checks as stated, replace the interval governor.
May 31, 2015 | Cars & Trucks
Have a xga 4000 amp only channel 2 works fine . Channel 1 very very low
Switch input connection pairs and if the 'fault' doesn't changes from one channel to the other it is almost certainly an amplifier or output fault.
Likewise switching the speakers. If after swapping the speaker connections the fault changes to the other speaker it is an amplifier fault. If not a speaker fault.
Aug 16, 2014 | Gemini Sound Products GEMINI XGA 4000 4000...
Boot priority order
Could be any number of issues Phillip. Have you tried booting into safe mode? After pushing the power button repeatedly hit your F8 key to get into the Safe Mode feature. Choose the first option which should be the regular Safe Mode without any connections. Try that and let me know what happens.
Jul 03, 2013 | eMachines Computers & Internet
Inspiron 2600 PC Notebook 4 beeps
4 beeps (1 long-2 short- 1 long) is a Programmable Interval Timer code (motherboard error). And 1-2-1 is a Processor Register Failure (CPU). About your only hope with a laptop is to pull the battery and (highly recommended if at all possible) pull the RTC battery and then press down on the power switch for a few seconds to totally re-set the BIOS. If no joy, you might one at a time remove the RAM, hard drive and the CD to rule out a short in those components. Next step involves removing the keyboard, etc. to get to components such as the LCD and the network card. Pull them one at a time and try booting. When you have tested all the peripherals that are plugged onto the MB, you can assume that the motherboard is toast.
Jan 12, 2012 | Dell Inspiron 2600 Notebook
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Power On
Sounds like it could be a defective battery. I'd try booting it from the AC adapter without any battery installed and see if that helps. Then a replacement battery is probably in order...
Please rate this answer if you feel it has helped you!! Thanks.
May 12, 2009 | Dell Inspiron 8600 Notebook
Inspiron 4000 won't start
Install the old RAM, download and install the A23 BIOS flash, then try the new RAM again.
Apr 17, 2009 | Dell Inspiron 4000 Notebook
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Inspiron 4000 problems
First, can it boot into BIOS setup? This is DEL, Esc, F1, F2, or whatever key your user manual instructs; press the requisite key immediately after pressing the power switch. Second, can it boot from an emergency recovery disk from the floppy, or a boot CD from the CD drive?
Mar 12, 2006 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
75 people viewed this question
Alun Cox
