Need code for toshiba dvd player sd4200kc
Need to enter my dvd into my tv and I dont know the code.Thanks
Gigatech
  • 259 Answers
SOURCE: I need a code for a Toshiba TV remote and a Cyberhome DVD Player
Try searching for your code. If it is not listed in the manual. Here are the instructions to search for your codes:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Here is your manual:
http://www.ofausa.com/remote_manual/CTGAE3P%203021%20anual%20booklet.pdf
Posted on Dec 12, 2007
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
dragonsthatk
  • 547 Answers
SOURCE: programing my toshiba ct-90157 remote to a sanyo dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Posted on Feb 12, 2009
greenspan
  • 1734 Answers
SOURCE: Need codes: OneforAll remote URC 4021B00 to TEAC or Toshiba
Ask http://manualfox.com - they can get it for you.
Posted on Jun 05, 2009
i need the codes for a rcu404 universal remote for sony dvd player
Posted on Aug 23, 2009
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Hiya, do you have a region hack code for a Toshiba SD3005? Thanks so much :):)
Found the following info.
Easy hack code to make it region free (make sure the TV is on when entering the hack code 98790)
Mar 10, 2012 | Toshiba Televison & Video
Toshiba d-vr18dtkb region free
HI
here a couple of site to try out for a region code enter the model of the dvd player and any numbers
DVD Player and Blu-ray Player region codes
DVD HACKS Home - DVD Hacks - UK DVD Player Hack List and Forum
riz.
riz.
Apr 14, 2009 | Toshiba Televison & Video
Need code to adapt to Toshiba HD flat screen TV
If it's a regional code that you're looking for
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want. Press enter again to memorize the code. Next press open/close. Put in your movie and enjoy.
if your movie starts playing in black and white:
To always watch in color if you do not have a Multisystem TV set Video output to Your TV system USA TVs- NTSC, Europe TVs PAL. This way You should always get color on Your TV
Hope it's what you were looking for. Good luck!
Mar 30, 2009 | Cyberhome CH-DVD 300 DVD Player
Can't find code
it would need to be programmed, need to know the make of your dvd player. But really most people dont program it because it is a pain. Every time you turn your tv and cable box on you will also turn on the dvd player and then have to turn it off. so it is better just to turn in on when you need it.
Mar 22, 2009 | Toshiba DR560 DVD Recorder
Toshiba Tv remote control
I NEED THE CODEOR CODES THAT TOSHIBA DVD-HD A30KU TU USE AND RECCEIVER ONKOY
Jun 09, 2008 | Toshiba HD-A30 HD-DVD Player
23 inch diagonal tv/dvd combination model # 23hlv87
with comcast red ok select switch 11256, 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast grey ok select switch 0154, 0156, 0060
May 20, 2008 | Toshiba 23HLV87 23 in. LCD Television
Need Remote Code for Toshiba HD-A30 HD-DVD Player. Thanks.
just pick from here
http://www.google.com.au/search?hl=en&q=toshiba+dvd+remote+control+codes&meta=
you may not find the exact one but the basic functionality for dvds should work.
Feb 01, 2008 | Onkyo TX-SR605 Receiver
Unlock to use Region 2 dvds
No region hack for this player.
Jan 29, 2008 | Toshiba HD-A30 HD-DVD Player
UNLOCK CODE TOSHIBA DVD PLAYERS
unlock code TOSHIBA D-VR7KC
Dec 26, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
