Question about Skytech 3301 Thermostatic Gas Fireplace & Gas Stove Remote Control System
I have a Lennox Model No:SKY-3001 change the batteries and re learn the security codes before changing all batteries I could turn the fireplace on with the on remote off switch. Now will not put the switch in remote and push MODE button on transmitter and receiver will beep but will not turn the gas on.
3 Suggested Answers
SOURCE: skytech model no. sky-3001 changed batteries in
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Posted on Jan 01, 2011
  • 4736 Answers
SOURCE: receiver was beeping all the
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Posted on Feb 03, 2011
Lennox Gas Fireplace. How do you replace a thermopile on a Lennox Gas Fireplace, Model # MPD4035CNM?
First take a picture of the logs so they go back in the same position . re move logs to gain access to pilot block thermopile is the lager probe of the two it comes undone by undoing the hex nut below it and removing the two wires on the gas valve its easy but fiddly.
Nov 11, 2016 | Heating & Cooling
Gas ventless fireplace remote will not work have inserted new batteries in both fireplace and remote but fireplace not recognizing remote
Every time the batteries are changed in the receiver and transmitter the transmitter has to be "re-learned" to the receiver. To do this locate the "learn" button which will look like a tiny hole so you have to stick the end of a pin or a pen in the hole to press the button. Hold the button down until it beeps at you 5 times and release. press the button again and release and then press Any button on the transmitter.
Once the receiver is set into its "learn" function it does not matter what button is pressed on the transmitter because the next signal the receiver picks up will be the frequency it is attached-to.
In order to change the transmitter simply hold the learn button down until it beeps 5 times again which tells us it has wiped out its memory. Then press, release and press the transmitter.
Nov 20, 2014 | Real Fyre 24" Forest Oak Ventless Natural...
Remote not work
May not be the remote-can you turn on the fireplace manually ? May be electronic ignition for fire place.
Dec 09, 2013 | Televison & Video
How do I sinc my fireplace remote ecs1001-a two button to fireplace
Each transmitter uses a unique security code. It will be necessary to press the LEARN button on the receiver to accept the transmitter security code upon initial use, if batteries are replaced, or if a replacement transmitter is purchased from your dealer or the
factory. In order for the receiver to accept the transmitter security code, be sure the slide button on the receiver is in the REMOTE
position; the receiver will not LEARN if the slide switch is in the ON or OFF position. The LEARN button in located on the front face
of the receiver; inside the small hole labeled LEARN. Using a small screwdriver or end of a paperclip gently press and release
the black LEARN button inside the hole. When you release the LEARN button the receiver will emit an audible "beep". After the
receiver emits the beep press ANY transmitter button and release. The receiver will emit several beeps indicating that the transmitter's code has been accepted into the receiver.
Oct 29, 2012 | Skytech 1001-A Fireplace Remote Control...
Skytech-3001 Thermo won't work
I am having some trouble! Mine became unconnected and I don't know how to reconnect. There is two wire, red and white, a box that sits inside the fireplace that has an on/off sitch and a box that sits outside the fireplace with a off/remore/on switch. How do I connect it back? Please help!
Jan 28, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
My remote control (SKY-3001) doesn't seem to communicate with the propane stove.
Sounds like either the batteries are weak or it's lost it's security code. Also, be sure the slide switch on the front of the receiver (the Black Box) is in the Remote position. If after changing ALL the batteries (4-AA in the receiver and 2-AAA in the hand held remote) and they're all positioned properly and it still doesn't work, check the LCD screen to see if the child lock or lock out has been activated. If so, deactivate by pressing the Mode button and the Up button at the same time and hold for 2 seconds. The Lockout icon should disappear.
And finally, if all else fails you'll need to reset the security code. There are 1,048,576 unique security codes, but you'll need only one.
When matching security codes, be sure the slide switch is placed in the REMOTE position; the code will not "LEARN" if the slide switch is in the ON or OFF position. Program the remote receiver to learn a new security code by using a very small scree driver to push in the LEARN button (on the top of the fron of the receiver to the left over the ON position) while at the same time pressing the MODE button on the hand held transmitter. A change in the beeping pattern, at the receiver, indicates the transmitters code has been programmed into the receiver.
The microprocessor that controls the security code matching procedures controlled by a timing function. If you are unsuccessful inmatching the securiy code on the first attempt, wait 1-2 minutes before trying again - this delay allows the microprocessor to reset its timer circuitry and try up to two or three more times
If all of the above solutions fails to solve your problem contact SkyTech Technical Service at 888-672-8929, Monday - Friday.
In the meantime, if you want or need to use your gas log stove for supplemental heating, move the slide switch to the ON position and the burner(s) will light. That's assuming that the gas control valve on the gas log stove is turned to the PILOT position. To turn it off, move the slide switch to the OFF Position and the burners will go out and the pilot will remain burning.
Good luck. Please let me know how it worked out for you.
Feb 06, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Receiver was beeping all the time. I changed batteries in receiver, and now remote does not control fireplace. Remote appears to be working fine. If I move switch to on instead of remote on receiver, it...
Feb 03, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech model no. sky-3001 changed batteries in remote and the transciever now i get nothing you can manually get fireplace to turn on using the transciever but when you switch it to remote and try to use...
Dec 18, 2010 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech 3301 Thermostatic Gas Fireplace & Gas Stove Remote Control System Logo
161 people viewed this question
Top Skytech Home Security Experts
Lawrence Oravetz
Are you a Skytech Home Security Expert? Answer questions, earn points and help others
