Question about Blenders
Kitchenaid blender accessory jar won't fit - Blenders
5 Suggested Answers
SOURCE: Jar blender blade bottom screw on piece
villaware 1-866-484-5529
Posted on Nov 20, 2007
SOURCE: my blender's jar is broken, i want a new one
You might need to order one from the UK and pay delivery charges? I am based in the UK and it is tricky finding this part, but I think possible. I smashed my blender measuring jug this morning and I hope I can get a new one at viewpointdirect@aol.com - just placed an order. You don't mention a model of yours but the one I found is compatible with several makes - check out this link http://www.viewpointdirect.co.uk/philips-measuring-jug---for-use-with-hand-blenders-573-p.asp. They deliver worldwide for a reasonably high charge. Else there are some other jugs you can find, without pictures though, which might be compatible with your make, at http://www.buyspares.co.uk. Good luck!
Posted on Jan 04, 2009
  • 38 Answers
SOURCE: Blades on inside of kitchenaid blender jar won't turn.
look on ebay for a replacement second hand unit
Posted on Nov 09, 2009
SOURCE: KSB5600BO kitchenAid blender blades broke and l am
If the jar is the one-piece polycarbonate (plastic) jar then you will need to replace (or have KitchenAid replace if it is under Warranty) the whole jar. If it is a glass jar then only the collar with integrated blades will need replacing.
Posted on May 07, 2011
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Kitchenaid blender
That part fits the top of the beaker to prevent the foods splashing out when blending.
Jan 27, 2014 | KitchenAid Blender Jar Lid Replacement...
Leaking
Unfortunately Kitchenaid's design on those blenders is a one piece unit, over time the seals wear out and you have to replace the entire jar assembly, they usually run 40-50 dollars and can be found from several vendors.
Here is a link to the replacement jar on our site: KitchenAid Blade Jar Assembly W10555711
Nov 28, 2013 | KitchenAid KSB560MC 5Speed Blender
I NEED A PITCHER FOR BLENDER MODEL KSB540WHO
The jar assembly for the KSB540 is part W10503762. this is for the 48oz jar assembly. Here is a link to the product KitchenAid Blender Jar Assembly for KSB465
You can also use the 56oz jar on your blender, which is part number W10555711, here is a link to that product as well: KitchenAid Blade Jar Assembly W10555711
Nov 26, 2013 | KitchenAid KSB5 Professional Stainless...
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to customerservice@mendingshed.com
Sincerely,
Mendingshed.com Staff
Aug 28, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My 5 speed KSBS kitchenaid blender is stuck together (glass and underneath part that would fit into motor base.
Have a look at the pictures here.
I think you are describing the blade unit's gasket being stuck. This can happen over time and especially if bits of food get stuck and harden. Try soaking for a long time in warm soapy water then keeping applying pressure until the seal between the gasket and jar gives.
Feb 12, 2011 | KitchenAid KSB560 5 Speed Blender
KSB5600BO kitchenAid blender blades broke and l am looking to replace them but I can't find the right parts. Do I need to just by the whole Jar assembly?
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Apr 19, 2010 | KitchenAid KSB560 5 Speed Blender
My son shove the mixing jar into the base when it
Hi, it is quite easy to replace. The simplest way is to use the spanner provided here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
instructions at:
http://kitchenaidblenders.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Dec 28, 2009 | KitchenAid KPCB348PPM Pro Line Series...
Blenders Logo
41 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
