Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Error de sistema C6050 en la fotocopiadora kyocera mita KM-3035
No permite ninguna funcion
SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Posted on Jun 19, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
  • 66 Answers
SOURCE: Kyocera KM-3035 System Error C0240
this is a printer error
it sound like you tried to update the printer firmware with an unzipped file from an incorrect print system
you need to format the cf card on the PC first then you need to format it on the printer, you will see the card option when you go into the user printer menu. it is print system U
Posted on Mar 10, 2009
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Posted on Jun 18, 2009
n25an
  • 622 Answers
SOURCE: Kyocera-Mita going offline
it sounds like there is an ip conflict... you may need to reserve an ip address just for the copier or failing that change your copiers ip address to one below the ip range... if it still has problems then I would check the network cables.... and see if you get any error codes... copier can go offline if 1. the print card is loose... bad mounting socket on the main board... ip conflict... someone else has the ip address... poor network traffic... the signals over the network cables are degrading too fast... so the copier gets a corrupt file or unfinished file and bombs out... power surge... this causes firmware corruption and the thing just starts shooting wierd error codes... I think I have given you enough to think about...
Posted on Dec 07, 2009
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera 2520 error c6050
it happen because there is problem with termostat of the heater unit
change that thermostat or connect the tow wires with each other
Sep 02, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
APARECE EL CODIGO C6020 Y NO PERMITE SACAR COPIAS
El codigo C6020 significa que hubo sobrecalentamiento en el Fuser. Si Ud. es tecnico en copiadoras, cheque la resistencia del THMS, ien caso de ser 0 ohms, reemplace. De otro modo, puede que la fuente de poder esté dañada. despues de hacer reemplazo de piezas, resetee la copiadora con el codigo U163.
En caso de no tener idea de que estoy hablando, le recomiendo solicitar servicio tecnico para la computadora ya que es un problema serio en el equipo.
Dec 07, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Can not print to Kyocer Mita KM-3035 from my computer
Try this PDF from kyocermita.be http://www.kyoceramita.be/content/pool/be/en/printer_multifunctionals/faq/i_need_detailed_information.-cps-80474-files-33494-File.cpsdownload.tmp/KX_Printer_Driver_Guide%20v1%5B1%5D.2.pdf
Aug 25, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
DISCULPE REQUIERO SABER EL ERROR A 400 DE MI COPIADORA KYOCERA MITA KM 1505, todo opera casi normal pero me bloquea con ese error a 400
bonjour ,j'ai une photocopieuse kyocera km 1505 et me marque le message erreur A400 ,y a t 'il quelqu'un qui pourrait me dire quesque c'est ce message là je vous remercie d'avance
May 02, 2010 | Kyocera KM-1505 Copier
Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
May 25, 2009 | Kyocera Mita KM-2050 Printer
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Error P.E
Intente quitar las bateria de la calculadora por un minuto, esta es la unica manera sensilla con que lo puede areglar.
Nov 03, 2008 | Office Equipment & Supplies
Sytem error C6050
This Code means low fixing unit temperature. If the power goes off and on, or Suzy Sec. has a space heater on the same circuit, this could be a false code.
Enter the service mode by keying in the numbers "10871087", on the key pad. enter the number 906, press start, press "execute"on the touch panel. The machine will reboot.
If the code comes back, you either have a bad thermistor, thermostat, or heater lamp. I have only had to replace the thermistor. The Fuser comes in the maint. kit ,so I always have some old ones laying around.
Jan 14, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
41 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
