IR3035 SMB scanning - Office Equipment & Supplies
2 Suggested Answers
  • 74 Answers
SOURCE: scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Posted on Mar 27, 2010
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Document scan to SMB for w8.1 pro for
That model does not support scan to smb
the only scanning it support is
TWAIN (scan-to-Pc and Scan-to-Email only via Software QLINK
Aug 19, 2014 | Kyocera Mita Olivetti D-Copia 163Mf...
Scanning error 2101 scanning to smb file
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
KM-1820 scanner setup
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB:
I am assuming you have the KM-1820 connected within the network and a static IP address for it.
open any Internet browser and go to KM-1820's IP address.
You should see the Command Centre web page.
Go to Basic page and add/register a contact within the Address Book.
Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center).
Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Dec 08, 2008 | Kyocera Copystar CS-1820 Black and White...
Can't scan to smb
in smb server, create a folder and give all rights, to that folder, if youre in domain, it may need you to use a password, so create a user and password and give rights that user in folder then go youre printer ip address, and add a contact, choose smb and fill in the fields. if error occurs, then choose details and you see whats wrong
Oct 30, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Smb scanning
check the firewall settings. ie exemptions
Oct 29, 2008 | Canon imageRUNNER 1023iF Black and White...
SMB Scanning to a Macintosh
I don't know if SMB for a Mac is supported on Bizhubs. I know it works with Microsoft workgroups. The only other way to get around it is to scan to e-mail. Then retrieve the e-mail from a Mac.
Oct 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Scanning documents
You need to use the Scan to SMB function.
First create a folder, share it over your network.
Go to the MFP and under the scan to SMB enter the IP and path to the folder, enter the ID and password for the computer.
This will scan to the shared folder.
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
67 people viewed this question
jasbo
jasbo
