Question about Denon AVR-589 Audio/Video Surround Home Theater Receiver HDMI 75 Watts
I connected a turntable to my AVR-589's analog AUX jacks, but the volume is extremely low. Does this receiver support a turntable?
robotek
  • 1512 Answers
SOURCE: What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Posted on Mar 16, 2008
Duncan
  • 218 Answers
SOURCE: Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Posted on Nov 28, 2008
petraman7
  • 1175 Answers
SOURCE: Output from Denon D-700?
Hi ...
If there's a tape monitor in/out on the D700,turn the tape monitor on and connect the "Play out" phono jacks on the 700 to the line-in on the computer. Spark up the turntable and you should be able to listen to the vinyl on the PC while recording.
Posted on Dec 30, 2008
Gurudristi
  • 98 Answers
SOURCE: I have a Denon AVR-1500 Reciever and I would like
How are you trying to connect your ipod to the Denon? i.e. What connector, or cables are you trying to use?
If nothing else work, you could try and use the headphone output of the ipod to connect to your receiver. ( Cable required would be stere pin to RCA stereo out). The volume control of the ipod will then become the gain control.
Posted on Mar 09, 2009
  • 128 Answers
SOURCE: I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Posted on Jan 25, 2010
Do you need a pre-amp to connect this turntable to a receiver that has no Phono input jack?
Yes, a TurnTable can be connected to any of the Analog Audio Input ports on the Sony STRDH130 Receiver. However, the turntable signal will need amplification from an external pre-amplifier (or an inline amplifier) as this Receiver does not have a PHONO input.
Feb 16, 2018 | Sony Audio Players & Recorders
My 1974 panosonic turntable has a low volume out of the receiver.
Are you sure you are going into a phono preamp? Turntables cannot work correctly if connected to the receiver's aux or tape input as they require much more volume boost which the phono input privides. Not many newer receivers have a phono input but an external phono preamp can be added (usually under $20)
Oct 07, 2014 | Audio Players & Recorders
What inputs on the Denon AVR 1500 do I use for connecting a turntable
If the turntable is old-school (not self-preamplified) just connect it to PHONO.
If the TT is self-preamplified use any available Line Level input, like AUX.
Dec 30, 2010 | Denon AVR-1082 Receiver
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
How i can add an old turn table
you'll will need a peamp device to boost the audio level of the record changer. preamps are still available try radio shack, they use to have one for about 40dls, but connect the turntable to an available input, something you are not using(aux) run a test with a record, you should be able to listen to the record but with a very low audio level, if you don;t then forget about the preamp and you'll need a a/d conversion device.
Jan 12, 2010 | Televison & Video
Jan 06, 2010 | Denon AVR-689 Receiver
Nov 26, 2008 | Denon AVR-1603 Receiver
Hi ...
Nov 21, 2008 | Denon AVR-1803 Receiver
SONY TURNTABLE PSLX22
You have to make sure your unit is connected to the PHONO INPUT connection on your receiver. If your receiver does not have a PHONO INPUT connection, then you will need to buy what's called a PHONO PRE-AMP - AVAILABLE HERE.
You connect the turntable to the Phono Pre-Amp, then you connect the Pre-Amp to the LINE IN or AUX IN of your receiver.
- Davis.
DIGITAL ANALOG THERAPY
www.repairnyc.com
Jul 05, 2008 | Sony PS-LX250H Turntable
TURNTABLE PROBLEM
You have a VERY nice turntable! TWO quick questions: 1) How do you define "minimal" volume? It is not NECESSARILY unusual that your turntable / receiver combination will have lower volume than your tuner, CD or DVD player. What happens when you CRANK IT UP?! Don't worry about the position of the volume control! 2)Are you changing the turntables output settings via the switch under the platter? Please post a reply and we'll go to the next step! Note: Ceramic cartridges are pretty much extinct. They were strictly low-end, low-cost, low-fidelity devices used in cheap audio systems of "yesteryear". Have you ever seen a BSR or Garrard turntable? Or your grandad's Magnavox Console Stereo? THAT'S where you'd find a ceramic cartridge!
Jul 12, 2007 | Teac AG-V1050 Receiver
Denon AVR-589 Audio/Video Surround Home Theater Receiver HDMI 75 Watts Logo
97 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
