Question about kawasaki Garden
Starter on my 25hp kawasaki won't engage - kawasaki Garden
traceylewis1
  • 363 Answers
SOURCE: Have 94 ram 1500 replaced starter and
are you sure you got the wires back on tight? Also it sounds like the bendex is not kicking out like it is supose to.....Did you change the starter cylenoied?
even some new starters are bad, it doesent happen much but it does happen. You might even take the starter back out and run Jumper cables to the starter. See if the bendex will kick out and stay out untial you diconect the starter......Sorry for your run of bad luck and I hope this is of some help.
Posted on Jun 21, 2011
  • 12 Answers
SOURCE: The car won't start, you
call auto store thay will tell you
Posted on Aug 09, 2011
egadgetguy
  • 258 Answers
SOURCE: Hi, have a toyota avalon, tried starting the car , it won't start, but then the starter engaged and won't turn off evenwithout the key, disconnected the battery and it stopped , when the batte
It sounds like you have a bad actuator. This is attached to the starter and has a solonoid that pushes the starter motor gears into the engine gear. If the solonoid is faulty this may happen. Also check alignment of the same.
Posted on Mar 18, 2012
kevin_getz
  • 1031 Answers
SOURCE: Starter won't engage on 17.5 koehler command
Try replacing the solenoid. If that doesn't do it, replace the starter.
Posted on May 06, 2012
  • 6468 Answers
SOURCE: starter motor spins won't engage flywheel on lawn tractor
take it off and see if the gear is broken (you can buy the gear at napa)or did the shaft the gear rides on got a little rusty over the winter
Posted on May 12, 2012
Kawasaki bayou 300 starter spins but wont engage all the time
The larger idler gear ring was spinning but not spinning the entire gear. I couldn't figure ... Starter Idle Gear Limiter Kawasaki Bayou 220 250 39076 1060 ' eBay ... kawasaki bayou 300 starter will not engage.
Mar 21, 2017 | kawasaki Motorcycles
Kawasaki problems
it can be a few things it can be a bad solonid, bad connection, bad battery, or your starter needs new brushes
Jul 23, 2014 | kawasaki 2010 Mule 600
Pontiac solstice starter won't engage
Check your fuses, then take a look at replacing the starter.
Jun 04, 2013 | 2006 Pontiac Solstice
Starting
Return starter bc the starter solenoid is not engaging bendix, which engages the starter teeth into the flywheel..
May 17, 2013 | 2002 Pontiac Grand Am
1965 mustang starter fires but won't engage flywheel. it is a brand new starter
Doesn't matter. The forks inside the starter may be missing or broke off or bad spring in starter that pushes the gear out. Try new started. Starter may have to be shimmed to make contact with flywheel. Starter may be kicking out but not engaging flywheel.
Jan 17, 2013 | 1965 Ford Mustang
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
check your flywheel & starter, one or both will be missing teeth, or the starter isn't "throwing out" yo engage flywheel
Aug 20, 2012 | 1989 Dodge Ram D-Series Pickups
May 05, 2012 | John Deere Garden
Mar 18, 2012 | 1999 Toyota Avalon
Hi!!!!! i have an kawasaki zx6r 1998 and it dosent want to start , i started it 2 days ago, but today it dosent want i charged battery, and when i push start button it dosent do nothing, i checked coil...
Check the clutch, neutral and side stand safety interlocks.
Double check that the bike is in neutral, and the clutch is pulled in when trying to start the bike.
If the bike is in gear with the side stand down, the bike cuts off all ignition.
If the clutch isn't pulled in, the starter won't engage.
Check all these safety interlock switches, and make sure you are in neutral with the clutch in when trying to start the bike.
Jun 27, 2011 | kawasaki ZX-6R Motorcycles
Garden Logo
37 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
