Question about Samsung RS2630SH Side by Side Refrigerator
How to increase the water level of Samsung SRS622DSS ice dispenser
  • 958 Answers
SOURCE: I have samsung refrigerator. There
hello pungli,
two things. first the water solenoid that controls the water to the dispenser. check it for resistance and presence of voltage when you press the lever to get some water. if there are no resistance, replace the solenoid. if there is resistance and there is voltage, solenoid could have been stuck close. if there is resistance and there is no voltage then the second thing..
second , is the switch that sends voltage to the solenoid valve. when you press the lever, it pushes a switch to send a voltage to the solenoid valve to let water in and comes out at the dispenser. try to check that switch for continuity and on and off as you press the lever.
i hope i was able to solve your problem. please rate me..tnx..
drcool299
Posted on Jul 09, 2008
garing
  • 998 Answers
SOURCE: samsung RS277 ice maker not filling with water
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Posted on Aug 22, 2009
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
  • 2069 Answers
SOURCE: Samsung RFG295AA Ice maker
You could try to Reset the ice maker. there should be a red button by the side of the icemaker. After resetting, wait 24 hours and check if ice production has begun. please also check this very useful guide on how to get on otherwise.
If your ice maker still doesn't produce ice after following all of these suggestions, schedule your unit for service
Posted on Jan 06, 2011
SOURCE: hi i have a double
There is likely a faulty solenoid which switches the ice dispenser between "crush" and "cube" mode.
The water pressure at the water dispenser is proportional to the supply line water pressure. Unless there is a restriction in the supply line or the dispenser line, the only way to increase the water flow is to increase the supply line water pressure -- not an easy proposition.
More info, let me know.
Charlie
Posted on Feb 12, 2011
Getting ice tray out of Samsung model RF2JBEDBSG
Is it frozen in? If so, thaw it and find out where water is coming from
Nov 12, 2017 | Samsung Refrigerators
I have Samsung rfridgewith freezer on bottom. We replaced the the ice maker but but now it makes ice just won't dispense
try defrosting the ice dispenser portion of the unit, it might have ice buildup stopping the auger from functioning
Jul 13, 2017 | Samsung Refrigerators
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Ice dispenser problem Samsung rf4287hars
Check that you ice maker is on, do you have ice in the bucket?
Check you ice drain is not plugged. Do you hear some humming noise when you push the ice dispenser? This could be a complex problem.
Feb 27, 2013 | Samsung Refrigerators
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    Hi i have a double door samsung fridge and when i place dispensable ice on cube i still get crushed ice in addition is there any way to increase the speed at which water comes out the dispenser
    Charlie
    Feb 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
    Samsung twincooling icemaker leaking water & overfreezing
    probably the water valve is not shutting of completly . this will flood the tray and then run over into the bucket. try // i would replace water valve . if this does not correct prob. replace the ice mker head as it time's the fill..
    Dec 11, 2009 | Washing Machines
    Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
    the fridge is making a noise , sounds like a fan catching and the water will not flow
    the firdge is a Samsung RS21DCNS 19.6CF
    Oct 04, 2008 | Refrigerators
    Samsung RS2630SH Side by Side Refrigerator Logo
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
