Question about Toshiba Satellite Pro L300 Notebook
Connect satellite pro l300 to samsung hdtv
I have a VGA cable connected to both, but only get a blank screen on TV? Are there settings on the laptop to change?
  • 35 Answers
  1. Right click on your desktop.
  2. Select Properties.
  3. Go to the Settings Tab.
  4. Click on the 2nd montior here and select Extend my windows desktop onto this monitor.
If this doesn't work you may be able to simply right click on the desktop and select the source to display output. However this only works with select video cards. Good luck!
Posted on Jan 20, 2009
  • 41 Answers
Press Fn + F5 this changes the active display mode
How to connect to a sony tv
If your laptop has an HDMI port you can buy an HDMI cable and connect to your Sony TV. Most TVs now come with an HDMI cable
Once connected your TV should show the screen from your laptop if not
press Function and F5 buttons simultaneously! Alternatively you can restart your computer!
Still problem! Go to control panel and click on display and choose Sony TV good luck!
Sep 24, 2011 | Toshiba Satellite Pro L300 Notebook
I would like to connect my PC to TV Grundig GU32DVD to wacth a movie from internet on a tv screen What should i do
Once you're TV is connected to the PC. Go to the display settings and check if the computer detects multiple monitors. Identify the monitors and set your TV as the main monitor. If this a laptop there is also a switch that will let you toggle from the PC display to the TV.
Check the TV output some TV's needs the channel to be set to the output where the PC is connected.
Some says PC some may say VGA or RGB. (depends on the brand of your TV)
Once that is the output channel is set and the cable is connected then you should be able to use your TV as the monitor and watch that movie.
Hope this helps!
Jun 07, 2011 | Toshiba Satellite Pro L300 Notebook
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
What cable do i need to plug a toshiba satellite L300D into a tv
depend on yr tv and laptop, normaly use hdmi cable to connect laptop and tv
Feb 19, 2011 | Toshiba Satellite Pro L300 Notebook
I don't know what kind of cable i need to connect my Toshiba satellite L305D laptop to my hdtv
depending on how old you laptop is because the L300 range has been going for a while will be either a HDMI cable or a VGA to HDMI cable but if you require sound and you have to use the latter you will need a headphone jack to auxhilary lead to go from the headphone port of your laptop to the line in on your tv
Jan 19, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop (Toshiba Satellite Pro L300 PC Notebook) Screen have wavy line. How to fix it?
I would plug the laptop into an external drive to rule out any mother board issue first. If it is still showing the wavy lines on an external drive then it is a motherboard issue. Otherwise, try reseating the cable connections from the motherboard to the display screen.
Hope that helps.
Dec 31, 2010 | Toshiba Satellite Pro L300 Notebook
How do i connect my l300 to my tv
Well if you have a newer tv,,that has on the back a computer hookup,,like vga,,,get a vga to vga cable,,radio shack has them,,and maybe other stores,,if your laptop has a s-video out the backl ,,get a that ,,if you dont have vga on tv,,good luck
Nov 20, 2010 | Toshiba Satellite Pro L300 Notebook
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite L300-the screen is black, have tried to switch off numerous, still no 'picture'. the lights showing power on etc r alight
Try pluging in a normal VGA monitor to the 15 pin HD D-type connector on the back if the screen is faulty this will spring into life at least then you will know if its your laptop internals that are at fault of just the screen.
If this laptop has no VGA plug it into an HDMI TV just to see if there is any life in it !!!
Sep 28, 2009 | Toshiba Satellite Pro L300 Notebook
I am not able to connect my Toshiba Satellite pro to my Toshiba tv with a vga cable When I power up the laptop, I get the response 'out of range; on the tv screen. What can I do? Thank you
Have you used the keyboard toggle to switch between the laptop screen and the TV?
If you have no then the toggle is as follows>>>>
Hold down the Fn key and look across the F keys for a key that has an icon of a monitor on it and press that.
Make sure you have the VGA cable connected to the laptop and the TV or the switch won't work.
Good luck.
Sep 02, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Toshiba Satellite Pro L300 Notebook Logo
178 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
