Question about JVC GR-DVL160EG Mini DV Digital Camcorder
@Hi I have a JVC and on playback I get 12BIT/Sound1 SP displayed on the screen how do I get rid of it?
2 Suggested Answers
  • 4 Answers
SOURCE: JVC mini Dv GR-D720E has small squares on playback
Indeed it seems that there was a really stubborn bit of dirt on the heads. I had to use the cleaning tape several times to ultimately have a clear picture on record and playback.
thanks again ,but successive cleaning can help for an effective cleaning of the tape path and heads.
Posted on Feb 05, 2010
FIND THE CODE TO GET RID OF THE WORD PROTECT ON MY JVC RECEIVER
Protect is displayed because there's a problem with your speaker wiring or there's a speaker shorted out. It's not there to tick you off for some reason.
So, you don't need a code. What you need to do is go sort out your wiring because somewhere there's two cables touching and the amp is trying to save itself from blowing up because you wired something wrong.
Sep 09, 2014 | JVC Audio Players & Recorders
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
Feb 04, 2010 | JVC GR-D73E Mini DV Digital Camcorder
Can't get rid of the screen images for video camera on playback
Hi
If it's like my Canon MVX25i date and time marking then go to the menu, select display setup (or whatever it's called on your camera) somewhere there should be a dialogue which allows you to switch the pesky thing off. I have never used date or time, a very amateurish concept in the first place.
Redars
Scorpigirl
Apr 15, 2009 | JVC GZMG435AG Camcorder
Git rid of display on screen
Hi There,
Can you access the Menu List from your front panel?
Mar 29, 2009 | JVC AV-32D305 32" TV
I can't keep writeing out of recordings and during playback.
Set the M, A, Off, and Play switch to M with a loaded tape. DO NOT touch the Refresh button. Press the Vol switch down one time, this will get you a Top Menu Page on the display screen. Use the Vol wheel to move about in this Menu page. Press the Vol switch again will let you into the different settings.
Luis J. Soria
Mar 10, 2009 | JVC GR-AXM17U Camcorder
Lens cap problem
i ma sure wht u talking about !!
Jan 01, 2008 | JVC GR-D33 MiniDV Digital Camcorder
Poor EP playback
hi sir
the speed in EP is differ from sp ,EP it is much slow then all quality would be less cause you are using less magnetic particles on the tape so here are many reasons for bad recording
first may be you have to clean video heads
or ,you have to clean the path of the tape in the recorder there are some metal guides that turnes with the tape to get it rounds the heads they may be dirty
or clean the capstain pinch roller and its metal roller that makes it run ( the capstain roller )
or you should have new heasd drum sir
regards
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
JVC GR-DVL160EG Mini DV Digital Camcorder Logo
16 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
