The button on the control panel r unresponsive the lights on the remaining time are not lit up the only the I get is if I hold the button for the control lock I replaced the CCU and have check the int
    Problem Solver:
  • 6 Answers
Sounds as if your cpu is in the "locked" position to not allow children to access. READ THE MANUAL or if you do not have one then download one or simply read it online. You spent money for new control and maybe did not need it................
Posted on Jan 06, 2013
  • 111 Answers
SOURCE: Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Posted on Jun 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: "Control Locked" light is lit. Washer won't start now.
Hi
Thanks for using FixYa. Press and Hold the "End Of Cycle" button so that it resets itself. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet WFW8300SW00 - No Power to Control Panel
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washer will not run, Kenmore HE2 Plus, Model# 47532601
Posted on Sep 25, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Kenmore HE2
Let's focus first on error codes F22 and F26. Error code F22 is door lock fault and it flashes when the door lock fails to activate after 6 attempts while F26 flashes when the door switch is opened for more than 5 seconds while the door is locked or when the door is not opened after 3 consecutive cycles. Since you cannot do 3 consecutive cycles without opening the door, this may indicate that the door switch contacts are welded together. But both error codes may also indicate a malfunctioning CCU or any other component such as the motor controller unit (MCU).
Disconnect power then start troubleshooting the machine by disconnecting the MCU wire harnesses (MI3 and MS2) from the CCU then reconnect power and start the machine. If error codes F22 and F26 go away, then the MCU must be the culprit, replace it. If the error codes do not go away, disconnect power then test the continuity of the terminals of door switch harness DS2 both with the door open and close. It must have continuity, if the door lock and switch assembly is good, when the door is close and none when the door is open. Also test the continuity between the terminals of connector DS2 on the CCU and it should read open.
Proceed with the troubleshooting of the door lock switch and solenoids if the door switch contact is open when the door is open and close when the door is close. Disconnect power then disconnect the door lock switch harness from connector DLS2 on the CCU. Jump a wire between the terminals of DLS2 on the CCU then close the door firmly. Reconnect power then start the machine.
Post back the result of the tests and your observations about the behavior of the machine as you do the tests. It will help determine which part is causing the problem.
Please make sure you accept the solution which you found the most helpful and informative. Failure to do so will automatically give credit to the last solution viewed no matter how unhelpful and non-informative it is. Accepting a solution will not prevent you from communicating with the expert at no further cost. You can still post clarifications and follow-up questions as long as you need further assistance regarding the problem stated herein.
Posted on Nov 03, 2010
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
I lost the codes for my reomote control i need to program my remote to my television
Hi! Try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The INDICATOR LIGHT will go off.
try searching for your codes by following the steps below.
I hope this helps.
Oct 12, 2010 | Universal Remote Control GE174Universal...
Need to find remote control access code for a zenith vr4135 vcr, using a rca system link 3 universal remote control.
Turn on your device.
Press and hold CODE SEARCH button until the indicator light lights,then release code search button.
Press and release the device button for the device you are programming (TV,VCR,etc).The indicator lights will blink once then remain lit.
Press and release OFF/ON until your device turns off.
Important you may have to press OFF/ON up to 200 times.
When your device turns off press the ENTER button,the indicator light will go off.
Jul 23, 2009 | Televison & Video
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
I have the rca rcu404 remote
Code Search Method
  2. Press and hold CODE SEARCH until the indicator light lights, then release.
  3. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit.
  4. Press and release off-on until your device turns off. You may have to press off-on up to 200 times.
  5. When your device turns off, press the ENTER button and the indicator light will go off.
Code Entry Method
  1. Manually turn on the device you want to program.
  2. Find the code for your device in the code list.
  3. Press and hold the CODE SEARCH button until the indicator light lights, then release.
  4. Press and release the device you want to program, the indicator light will blink then remain lit.
  5. Enter your code using the number buttons.After your code is entered the indicator light will turn off.
  6. Aim the remote at your device and press the off-on button. The device should turn off.
here is the codes for the toshiba tv's : 071, 105, 162, 160, 049, 072, 109, 117, 118, 201, 207, 232
Jan 06, 2009 | RCA RCU404 Remote Control
SHR 1040 "Froze Up"
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Dec 23, 2007 | Samsung 4 Channel Dvr
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Brother HL-5250DN
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Sep 01, 2007 | Brother HL 5250DN Laser Printer
Washing Machines Logo
Top Washing Machines Experts
