Question about Dell Dimension 4600 PC Desktop
PC will not boot from CD drive
Hi Thunder,
Thank you for your suggestion of using the winxp floppies to enable the PC to boot from the CD drive.
Actually, I am not the one with the problem -- I'm trying to help my sister with her Dell Dimension 4100 (FixYa did not list the 4100 in the drop-down menu so I selected the 4600 as the closest option).
She's currently having (unrelated) trouble getting online and hasn't had a chance to download the floppies yet. While she's dealing with the cable company I thought I'd ask you a couple questions. I'm a technician myself but I work for Metro in Washington, D.C., as an automatic train control (ATC) tech -- I know just enough about computers to be dangerous, so bear with me!: 1) Since her PC doesn't even begin to try and boot from any of the Windows CDs she has (95, Me, XP Pro) I'm curious how using the winxp floppies will help. 2) Because I'm in Maryland and she's in Iowa, I'm trying to help her over the phone and sometimes there are 'communication problems'. For example, after I posted my question she told me that while the DVD drive works (will play audio CDs) it has what seems to be a mechanical problem -- when she tries to load a disc into it, the DVD drive often kicks it right back out. Therefore it turns out she apparently has _not_ tried to boot from the DVD drive, only the CD drive. My question is: Does it matter if the CD drive is '0' or '1' in the BIOS? I was thinking that if the DVD drive does have some sort of problem, the PC may go there first to try and boot and then skip the CD drive and go straight to the existing copy of XP Pro on the hard drive. In any case, that's what's happening -- no matter what she's tried, the PC ends up booting from the hard drive (except when we disabled it in the BIOS as a test). She even went to Dell and downloaded and installed the latest version of the BIOS for her PC. Thank you Thunder. I'll be sure to rate your suggestion once my sister has a chance to try it. Sherman
  • Sherman Johnson Jan 26, 2009
    Thanks to both Thunder and mklocker.
    I got an email today from FixYa asking me to rate your solutions. I haven't done that yet because my sister got her existing version of XP to work (for now) and is reluctant to reinstall Windows unless she absolutely has to.
    I'll keep you posted.
    Sherman
    Champion:
  • 253 Answers
Disable the harddrive in the bios and set the cd to 1 boot.Check sometimes there are 2 cd drive .Cd-rom and the number or model of the dvd drive...
Posted on Jan 23, 2009
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Bootable USB
rreadow To Boot From A USB Flash For starters this is still a new science and many people have had good luck with at least one of these methods and others have not. Note that flash drives are often also called thumb drives, keychain drives, pendrives, etc. A FEW THINGS YOU NEED TO CONSIDER IN ADVANCE. 1. The PC has to support booting from a USB flash drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
zivider.gifzivider.gifzivider.gif METHODS Method 1 - Make your flash drive bootable using Bart's mkbt util:
http://www.nu2.nu/mkbt/ | Alt: mkbt20.zip Put a bootable floppy disk in your A: drive or create one using Windows.
Download mkbt20.zip and unpack to to new temp folder you create.
Go to the temp folder.
Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type: mkbt -c a: bootsect.bin The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created. Format the flash drive in FAT or FAT16. Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type: mkbt -x bootsect.bin Z: "Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly. Now you can [grin] "should" be able to copy the utils you need to the pen drive.
zivider.gifzivider.gifzivider.gif Method 2 - Try these 2 HP/Compaq USB Flash Drive Utilities. They work with many other brands of flash drives as well. HP USB Disk Storage Format Tool Version 2.0.6
HP Drive Key Boot Utility Version 7.41
Download
zivider.gifzivider.gifzivider.gif Method 3 - Third Party Links http://ucsu.colorado.edu/~shaher/Bootable_USB.html Recall I did say it's a new science.
http://www.microsoft.com/whdc/device/storage/usb-boot.mspx
zivider.gifzivider.gifzivider.gif Method 4 - A Bootdisk.Com Visitor Suggested Here is my another method for creating dos bootable USB sticks using windows format. 1. From Win98 DOS-Prompt type "SYS {USBDriveLetter}:" or "FORMAT {USBDriveLetter} /U /S". If from WinXp then from start->run command.com execute format.exe copied from win95 or win98. OR 2. Simply by enabling copy system files in windows explorer format window. By default it is disabled for non-floppy drives. To enable it use windows enabler program from http://www.angelfire.com/falcon/speedload/Enabler.htm an whoila it works.
zivider.gifzivider.gifzivider.gif Method 5 - Another Bootdisk.Com Fan Suggested - Thanks Keith First if you don't have a physical floppy drive (and don't want one) you can use the [free] "virtual floppy driver" from here: http://chitchat.at.infoseek.co.jp/vmware/vfd.html With that you get an A: drive and can manipulate a floppy image as if you were using real floppy. You can then use that image to make a bootable CD. It's not that user friendly but once you get how it works it does work perfectly. Even cooler you can use a "raw write" utility like dd for windows to write the floppy image directly to your USB thumb drive. Even without that famous HP utility to do the magic this will make your USB thumb drive bootable. The 'dd' ported to Windows is located here: http://www.chrysocome.net/dd Another trick you can use with that dd utility involves MS VritualPC (which is free). You can create a virtual machine/virtual hard drive, set it up the way you want then use dd to "raw write" the virtual hard drive image to the thumb drive; this will make the thumb drive identical to the image, including bootable (again, no HP utilities required). Of course, your thumb drive will effectively have the capacity the size if the image in question (your 1GB flash drive will effectively be 1.44 Megs).
Sep 13, 2008 | Computers & Internet
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
How to install Windows XP onto a newly formatted laptop
put winxp cd in tray
at boot up press F12 - right-arroweto CD icon --> Enter
winxp should go into install
you'll probably need a version of winxp that can recognize Sata hdd. or hae sata drivers handy.
Oct 13, 2009 | Toshiba Portege M200 Notebook
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
Boot cd problems
You can't just put the windows cd in your cd rom drive. If your going to change your boot order (to cd), then you HAVE TO use a BOOTABLE cd. That means a bootup disk with all the correct bootable files for WINXP. Same with a floppy. Change your boot order to a floppy....and in order to bootup windows, you MUST HAVE the bootable files ON THE floppy. In your case...the cd. The windows xp does not have the bootable files since it is only used for install and reinstall.
Create a bootable CD or floppy (((from someone elses WINXP pc or laptop))). There is a feature that allows you to do that. Then when you boot to cd it will start windows and give you options.
Mar 31, 2009 | Panasonic Toughbook CF-27 Notebook
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
We want to install win Xp in Toshiba Satallite A205-S5825
Depending on the model of your Toshiba, it may have an unsupported hard disk controller which requires that you load a disk driver from a floppy disk by pressing F6 when prompted during the boot of an XP installation CD. If so, you will need to download the apropriate driver and put it on floppy diskette, Of course a floppy drive will also have to be available during the boot. (enable USB legacy support in BIOS if you use a USB floppy drive)
Alternatively, check your BIOS settings to see if the disk controller can be set to operate in ATA mode rather than AHCI mode. ATA mode should work with the XP cd-rom.
Dec 06, 2008 | Toshiba PA1381U-1ETC Consumer Headphones
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Dell Dimension 4600 PC Desktop Logo
809 people viewed this question
Alun Cox
