Installed unit last year never tried heater
SOURCE: Wiring schematic - RUUD
Schematic
All Projects with Photo Preview Browse over 10000 circuits. Now!
www.ElectronicsInfoline.com
Posted on Jan 08, 2008
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
Posted on May 30, 2008
SOURCE: ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Posted on Nov 22, 2008
SOURCE: Replacement of filter on Ruud Achiever series heat pump/AC
You must first remove the blower compartment panel. The filter should be in there. However, since this unit is in a crawl space you may have a return air filter grill. Look at your return grill. Does it have a filter? If not does it have latches so that you can open it? If so measure the opening and install a new filter there. I hope this helps. Please don't forget to give me a Fixya rating.
Posted on Feb 23, 2009
SOURCE: How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Posted on Mar 21, 2009
Jun 22, 2014 | Ruud Matching Split Air Conditioner
May 20, 2014 | Ruud Heating & Cooling
Jul 26, 2011 | Ruud Matching Split Air Conditioner
Jun 26, 2011 | Heating & Cooling
May 02, 2011 | Heating & Cooling
Jan 07, 2011 | Heating & Cooling
Jun 18, 2010 | Ruud Central System Air Conditioner
Feb 21, 2009 | Ruud UBHC Air Conditioner
48 people viewed this question
