Question about Sewing Machines
My jumbo hoop for my bernina 830 wont tighten, just like that. i took out a block and was loading stabilizer for the next block and it just wont tighten
  • 185 Answers
SOURCE: bernina deco 600
Sorry to inform you but your machine only sews 4" x 4" . The arm on the machine can only move 4 inches up and down and 4 inches left and right.
The size of the hoop does not affect this. If you have a multi position hoop you can sew multi 4 x 4 areas without re hooping.
Posted on Feb 28, 2008
  • 52 Answers
SOURCE: bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: Bernina 830 stuck
You probably have a crack in the cam gear.
Posted on Jul 25, 2009
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
  • 8 Answers
SOURCE: bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
Posted on Sep 06, 2009
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
Feb 11, 2017 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
My knob on the Master Hooper is stuck and I can't turn it. I have an 830 Bernina
Use a pair of small pipe grips and hold the pulley wheel at the same time it wont be that tight.
good luck
Feb 08, 2015 | Bernina Sewing Machines
I have a bernina record 830 and i want instructions to install motor on it
You ought to look at the link below. The site is in German but contains loads of information on the linked page and also elsewhere. German isn't insurmountable as a problem these days with all those translation facilities.
830 Record Serie Herzogenbuchsee Info BERNINA Service Tipps Lenco...
Feb 03, 2015 | Bernina Sewing Machines
Need to download a free repair/service manual for a Bernia 830
Request the repair/service manual directly from Bernia (Bernina?). It may or may not be downloadable.
Jan 04, 2015 | Sewing Machines
How to change hoop size in my Bernina Artista 180
I don't have a bernina.. but on my Janome... I have to "tell" it what size I'm using by selecting it from the menu.
Mar 14, 2013 | Bernina Artista 180
Jumbo hoop
I assume you mean the clips that attach the hoop to the embroidery unit. You just hold the hoop by means of the two clips, with a thumb and other finger on the outside of each clip - pressing them together allows the hoop to be put onto the two clips on the Y arm of the embroidery unit. When you release the spring pressure, the hoop should be retained in place on the Y arm.
Nov 25, 2011 | Bernina Sewing Machines
Bernina deco 600
Feb 28, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
98 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
