Question about Whirlpool Duet GHW9150P Front Load Washer
I have a DUET HT . I have been having "H" & "F" problems for the last 2 months and been turning off and unpluging to reset. This time i pushed Control On but when I hold to starty nothing happens.
  • whackywasher Jan 21, 2009
    That was the problem before now when I hold the start button nothing happens.
  • 61 Answers
"H" & "F" means no water is coming into the washer, check that your faucets are on, hoses & screens on hoses,if all this is working properly, it could be your water valve or if the washer has water inside and the pump is not pumping it out, for safety reasons the washer will not fill and you will get the codes f h or l d.
Posted on Jan 20, 2009
I have a Onlyo HT-RC460 about 6 month. The HDMI got a lot of problems. Every time turn on the Receiver only had video no sound. after switch the out put to different one it works. It is last 2-3 month in...
can i suggest you go to there site and see if there's a firmware upgrade, if you have not done this then also try changing the leads if.... connected to tv from box, most common is the firmware not upgraded good luck.
Nov 14, 2017 | Onkyo HT-RC460
Hi, my name is Uwe Gemba. Our duet sport Ht is not draining the water out. error F-21.
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
(Courtesy JSRock)
Thanks for using FixYa
Dec 21, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Hi I have a whirlpool front load washer model number ghw9100lw my problem is that i am getting a f05 code i have changed the temp sensor and i am getting the same code i have unplugged the washer now when...
Check and replace
- Flowmeter.
- Water inlet valve
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet HT and the control is locked. how do i unlock thanks
Mine is doing this all the time, I finally got tired of pulling the washer out to unplug it so I plugged the washer into an extension cord that's easily accessable, so unplug it for at least 30 mins before you plug it back in reset to drain and spin cycle for 12 mins and your load should finish ok. These washer and dryers are beginning to be a pain in my....neck.
Feb 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 01 code comes on when trying to start another load. Pushed the cancel button and the machine shuts off also tried unplugging it and that does not work either
F1 error means a communication error, if you unplugged it, for more then 2 mins that should have work, but you also have to verify ccu operation by running a diagnostic test
Jan 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Control Lock is on, how do I reset the machine?
Press and hold down "end of cycle" button at right side of panel for 3 - 5 seconds. This is the child lock feature, do it again and the machine locks.
Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Samsung HT-P38 won't play DVDs but plays CDs just fine
I called Samsung. They told me how to do a software reset and solve the problem
1. Take out all CDS.
2. Turn off and then on.
3. HOld down stop for 5 - seconds.
Problem Solved!
Apr 11, 2007 | Samsung HT-P38 System
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
