Question about Avanti Hot and Cold Water Cooler
REPLACEMENT RECEPTACLE ASSEMBLY, 5 PARTS FOR SUNBEAM WATER COOLER YLR 2-5 90 H23
PART HAS WARPED AND WATER IS LEAKING
2 Suggested Answers
SOURCE: sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
My sunbeam water cooler is steady dripping water what is the problem
Make sure the part is screwed in completely. I have expired model ylr2-5-87h3 and no one makes parts !!!!
May 30, 2014 | Tomlinson Sunbeam WATER COOLER FAUCET...
Leaking coolant intake
either bad intake gasket ,warped or cracked intake manifold,cracked or warped head,or head gasket blown if u have access to a radiator pressure tester pressurize the system and use a mirror to try and pinpoint the exact location of leak
Mar 31, 2014 | 1995 Toyota Pickup
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
95 honda gold wing 1500 over heating
oh dear
this could be a number of things
from a leaking radiator or a leaking inlet manifold to warped heads or at the worst cracked cylinder liners
check the colour of the oil to start with
if it is a grey sludge texture then you have water mixing with your oil
as a matter of urgency
you need to have this looked at in a workshop for full diagnosis
a full compression test would diagnose a warped head or a cracked cylinder liner
get them to also check the cooling system for a blockage
Dec 03, 2012 | 2001 Honda GL 1800 Gold Wing
Sunbeam hot shot leaks
Unfortunetly, most modern manufacturers do not supply replacement parts, however if the unit is still under warranty, you could probably have it replaced for free. Contact the manufacturer or retailer.
Nov 16, 2012 | Sunbeam Hot Shot Hot Water Dispenser Black
I have a antifreeze leak on a 2003 ford sports trac
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802e4058#hd1-1-1 Hi Donna,here's a link to the water pump diagram,is the mating surface that the gasket goes on clean and not badly scraped up from removing gasket,the pump itself is aluminum and could be warped and not sealing good causing it to leak,maybe you need a new water pump,hose on that side isn't leaking?
Oct 12, 2012 | Ford Vehicle Parts & Accessories
Oil & water mixing
If there is oil in the radiator or if there is water in the oil, then you have a head gasket leaking and possibly a warped head.
Oct 03, 2011 | 2004 Mercedes-Benz C-Class
BMW 520i 1996 over heating no water is in the oil and the water is not leaking any where
you have a blown head gasket, or a warped valve head. fill it up with water in the radiator look for water comming out of the tailpipe but if there is water in the oil 100% blown head gasket or warped or cracked valve head
Jan 15, 2010 | 1997 BMW 328
Avanti Hot and Cold Water Cooler Logo
258 people viewed this question
Top Avanti Water Filters & Coolers Experts
John Tripp
John Tripp
john h
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
