Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
How to remove muffler on the 455 rancher - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
  • 13 Answers
SOURCE: how do i remove the cluth drun on a husqvarna 455
Hi, first take off the clutch cover by removing the two bar nuts.
The nut on the clutch is left hand thread. You need to have some sort of piston stop to bind the engine when you remove the nut. They make tools just for that( it's called a piston stop) but I like using a small piece of rope. Just take out the spark plug, run a bit of the rope down in the cylinder and that will hold the piston really well. You could use a lof of things for that, I would be careful that it's something that won't gouge or mess up the top of the piston though. When you have that done you can remove the nut holding the clutch assembly on and remove the drum. ( REMEMBER that left hand thread ) Hope that helps you.
Posted on Jul 24, 2009
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a husqvarna 455 rancher. It was working
Why would you pay for something and then not force them to make good? I have a large bridge for sale, CHEAP. Make you a heck of a deal.
Take it back!!!
Lou
Posted on Sep 17, 2009
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
dontbother10
  • 2220 Answers
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
Remove limiter tabs on a carb off a 2012 455 rancher
need special tool to adjust carb can buy them on ebay.
Oct 18, 2014 | Husqvarna Garden
455 rancher wont rev
remove the muffler and try running it if ok open the muffler and clean off the screen
Apr 15, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Refilled the fuel on my Huskvarna chainsaw and now it wont restart
Just check that it is mechanically sound, remove the muffler and check the condition of the piston skirt through thre open exhaust port, any signs of scuffing or damage and the cylinder will have to come off the assess the damage,
Oct 24, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
I have a Husqvarna 455 Rancher - about 1 month old. Worked perfect one day. Would not start the next. Feels like there is no compression. Second 455 with this problem.
There is only two reasons for low compression, either the piston ring has gummed in, or the piston has seized, remove the muffler and check out the condition of the piston skirt through the open exhaust port, any signs of scuffing and the piston has seized, it will then need to come apart to see how much damage has occured. Saws today are set up very lean on the mixture to get the best emmissions not the best running, they realy need to be using the very best two stroke oil.
Sep 09, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna rancher 55 chainsaw having problem starting have spark new spark plug, plug is wet after trying to start it
You need to check that this machine is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing ( seizure ), and the cylinder will need to be removed to assess the damage
Aug 27, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My Rancher 455 shut down on me yesterday. I have only ran it for an hour now and it now it wont start. I checked the gas/oil and it was a bit low so I filled it back up. One thing I was told was to make...
I think before you go any further you need to check the saw is mechanicaly sound, remove the two screws from the muffler and remove it, check the condition of the piston skirt through the open exhaust port, any signs of damage or scuffing, and the saw will have to come apart for further investigation
Jul 23, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I take the muffler off a rancher 455 husqvarna chain saw?
two 6mm screws sunk down inside the muffler, use a 5mm allen key to remove
Dec 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher has no power at full throttle, but will start and idle normal.
Check for plugged fuel filter, air cleaner, and muffler. Check the fuel lines for decay or other damage. Check the chain for proper oiling and not so tight that you can't turn it by hand. Hope this helps!
Nov 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
