Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Lamp engine I have a real annoying noise I believe coming from the lamp engine that doesn't go away when the set is warmed up
  • 6 more comments
  • allieg04 Nov 17, 2007
    I have the same problem. It's kind of like a hissing/buzzing noise when the TV is on, and it's already warmed up. I still have picture and sound.
  • Anonymous Dec 07, 2007
    I too have the same problem, and it is really annoying, especially when viewing a show with surround sound turn on, during a "quite" session.
  • Anonymous Apr 08, 2008
    I highly recommend rivervalleyelectronics on e-bay for purchasing lamps, color, wheels etc.
  • ThomsonSucks Apr 20, 2008
    I got the same noise after half an hour. First I thought it is a fan but the noise comes from the color wheel that is located next to the bulb. Reading the UL number on the flexible cable (UL E182394) I found out, that this part comes from Delta Technology Inc., a company from Taiwan. The noise comes from a aging bearing so the color wheel and motor needs to be replaced. If you got no fear and some experience in handling electronic devices, it could be done in half an hour - if you can get the color wheel as a spare part. The company that built this TV for RCA (in the US) and Thomson (in Europe) went bankrupt and the manufacturer in Taiwan did not answer. Maybe he starts to answer emails if you ask for containers :-)
  • dentdang Apr 27, 2008
    purple line and loud noise.
  • murphydog239 Jul 06, 2008
    we have the same annoying sound trouble as well. recently the top left corner of the screen has gotten (what we call) a shadow triangle, where the colors are not as bright. where can we get replacement parts and instructions to install on our own?
  • bignutz787 Mar 31, 2009
    I had the same problem but it went away. expecially after it warms up. but i just replaced my bulb last summer and now its starting to act up again. my main gripe is that the screen flickers like the lighter colors are 'washing out'. when i first got the tv, it did it a little. then it was fine for a year, then last year it happend when it got hotter than 88 degrees F out side. then the bulb blew. after replacing the bulb i didnt have the flickering problem anymore. now it seems to flicker when it drops below 65 degrees F or goes above 75 degrees F. I think ill just sell this $3500 peice of ****. sad because i always loved RCA products.
  • Michel Kahlke May 11, 2010
    Hey guys,
    I called Delta Electronics in Germany and Netherland.
    As in the comment of ThomsonSucks I found the same number, but serveral other information on the cable. So I told these number to the guy I talked to and he sent an E-Mail to a collegue in Taiwan, so I guess to get an answer tomorrow. One of the Numbers seems to bee a SAP-code with the other on he could not work. Now I am curious if I can get a new motor from them. Has anyone tried to us another color wheel from RCA? I found RCA 267888 color wheel that looks pretty similar to mine one from a THOMSON.
    FYI: THOMSON Scenium 61DLX648
    Problem Solver:
Nobody has provided written instructions on how to replace it,nor where to economically purchase it (color wheel)...
Posted on Apr 07, 2008
    Problem Solver:
  • 17 Answers
Replace color wheel
Posted on Apr 06, 2008
SOURCE:
Whirring noise on acceleration Jeep Compass 8 months out of warranty done 24,517 transmission fault. any goodwill?
we cant hear noise here.
unless REAL LOAD.
heheheheh
ok,, why not ask a real live person this, in a real shop.? in the flesh.
noise, keyon?
noise , running engine.?
noise only in drive or reverse?
noise only moving>?
we can see you either.?
where is the noise, the car big, noises first must be source locate
as car has like 4000 parts on it that can get loose. even a loose license plate.
only on acceleration>?
is the CEL lamp glowing. (cluster warning lamp)????? at noise time?>??
may be engine noise (misfire) or trans. on drive line, all of it.
get it serviced like 99.9% do today.
Nov 27, 2016 | Jeep Compass Cars & Trucks
Check engine control light is on right after starting the engine
CHECK ENGINE LAMP
Monitoring the operation of the various inputs and outputs is what on-board diagnostics is all about. When computerized engine controls went nationwide in 1981 to comply with federal emission regulations, the "Check Engine" lamp became a new feature on the instrument panel.
The "Malfunction Indicator Lamp" (or MIL as it is called today) is supposed to alert the driver when a problem occurs in the engine control system. Depending on how the system is configured and the nature of the problem, the lamp may come on and go off, remain on continuously or flash. Some types of intermittent problems will make the lamp come on only while the fault is occurring. When the problem goes away, the lamp goes off. Other types of problems will turn the light on, and it will remain on until the fault is diagnosed and repaired.
The Check Engine lamp has proven to be a great annoyance to many motorists (as well as many professional technicians) because it seems to have a mind of its own. For one thing, it doesn't tell you anything about the nature of the problem. It might be something serious - or it might not. There's no way to tell without plugging in a scantool, such as AutoTap.
Consequently, many motorists ignore the warning light and keep on driving if they don't hear, feel or smell anything unusual (even then, some continue to push onward until things get worse or the engine dies altogether). It's amazing the lengths some people will go to just to avoid a quick diagnosis when the Check Engine lamp is on. Many people don't really want to know what's wrong with their vehicles because they fear it will end up costing them several hundred dollars to get it fixed. So they'll put tape over the lamp, attempt to disconnect the bulb or cut the wires to the bulb - in an attempt to make it go away. But engine performance problems don't go away and they don't fix themselves. And for motorists who live in areas with vehicle emission testing, the day of reckoning arrives sooner or later since modern emissions testing uses a scantool to check if the Check Engine lamp is on, and if the light has been tampered with. Whenever the Check Engine light comes on, a "diagnostic trouble code" (DTC) is also recorded in the on-board computer's memory that corresponds to the fault. Some problems can generate more than one fault code, and some vehicles may suffer from multiple problems that also set multiple codes.
Good for you.
Rate this solution please.
Mar 07, 2010 | 1998 Toyota Camry
Loud noise coming from Lamp area
The fans in these generaly do not go bad, the part nubmer for the lamp cooling fan is 265943. But my guess is that the color wheel is starting to go out of you light engine. I am not sure if these are still avalable but the part nubmer for it would be 267888. Worst case you could send your engine in for repair engine nubmer should be 265864 or order a repacement try this site. GOOD LUCK http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD50LPW165 50" Rear Projection HDTV
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung Tantus HLN467W High pitch noise from dlp?
noisycoil- idetify the coil and remove it.coat it with laquer suitable for motor winding, reinstall after dry.
Dec 26, 2008 | Televison & Video
Samsung dlp tv hls 5688w problem
Possibly a bad fan. operate the set for at least an hour to warm it up then shut it off does the noise continue for a moment? If so its probaly the fan for the lamp that is making the noise.
Mar 20, 2008 | Televison & Video
ESD noise (fluorescent lamp power-on) also wakes the computer from standby
Make sure Wake on function turned off, Wake on LAN, modem ring...(Bios Setup)
Use a surge protector anyway!!!
Conect the lamp to a difrent place away from the computer.
You can buy expensive filters too or just buy a new lamp.
If you can try the lamp with another computer, make sure whats the real problem!
Nov 11, 2007 | Gigabyte GA-7VRX Motherboard
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
815 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
