Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon MP500 error message
I keep getting this error message on my Canon MP500: "UO71 More than one ink tank of the following color is installed, BK".
There is not the same color installed and I have replaced the one blk cartride just in case with no results.
  • Canon Master
  • 419 Answers
If you're using Canon OEM (branded) cartridges you're going to need to ID the problem chip/cartridge so I'd try and get hold of some empty originals from somewhere (CartridgeWorld or similar perhaps?) and put those in as replacements for one cartridge at a time until you ID the problem cartridge/chip
If they're non-branded then chances are you do have more than one of the same chip but the solution is much the same...
If all else fails, take the printer to a friendly retailer who sell Canons and ask them to help you ID the problem cartridge.
Posted on Jan 23, 2009
UO43 error there is no ink cartridge there, but when there is an ink catridge UO71 it says more than one ink cartridge
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 08, 2010 | Canon Pixma MP500 All-In-One InkJet...
I have error U071. I have been refilling the
You will need to get a new(er) print cartridge and replace the old one to eliminate the problem.
Feb 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Alarm light is on and it won't print
I get the same error message. I pull out the yellow cartridge and put it back in. It will print a couple of times and I get the same message. Need a permanent fix.
Sep 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
i had the same problem and when i checked inside to see why it was not working with the cyan i saw that a sensor was the problem... it had fallen out. check it out and let me know if it is the same with yours.
May 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Cannon Pixma MP500 - Waste Ink Reset
I don't belive there is a reset device for the MP500 tanks. However, when you get the empty error message, just follow the instructions about pressing OK as many times as it asks for (I think it is four time). At that point, you can continue to use the cartridges. The printer will no longer keep track of the ink level. You will have to do that yourself. But, you can continue to use the printer with all colors.
Dec 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
Aug 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
U071
sometimes when you change your ink it doesnt register.hold down the stop/reset button and it will bypass that
Aug 23, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 UO71 error
I am also getting this error message. For a few days I could take out the offending cartridge and the printer would forget for one printing and then go back to telling me that two of the same cartridges were installed. HELP! I am about to chuck it out the window, though I believe CANON should send us all new ones.
Aug 15, 2007 | Canon Pixma MP500 All-In-One InkJet...
Pixma mp500
Canon Technical Support team will be able to help here. This seem a common problem with the printer firmware.
Jul 08, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
130 people viewed this question
old marine
old marine
