Question about Pool & Spa
1.0 hp fx pool & spa pump manual
7252qtd-a11
  • 93 Answers
SOURCE: I have an A.O.Smith Century Pool & Spa motor
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Posted on Jun 20, 2009
john224
  • 1378 Answers
SOURCE: Motor has died, how to disconnect from pump. 2
The thru-bolts hold it to the seal plate and the impeller is threaded onto the shaft.
Posted on Aug 10, 2009
  • 6 Answers
SOURCE: why does the spa empty when the pump shuts off?
This problem can be caused by a couple things. the two most likely culprtits are either the absence of check valves and or incorrect actuator settings when the pump shuts down.
Your spa is most likely higher than the pool. You most likely have a spill over (waterfall) feature from the spa into the pool. This is so the spa water can be recirculated in pool mode. One of your actuator valves may be slightly off closed position in order to allow spill over in the spa, or you may have a dedicated overfill pipe in the circuit to feed water to spa in pool mode.
Whichever spill over piping you have set up, when the pump shuts down, water from the spa ( higher level than the pool) will backfeed through the overflow spa circuit, back through the pump and into the pool through either drain or return. Effectively rendering your spa level the same level as your pool.
To fix this problem, simply install check valves into the spa runs and as a secondary measure put one into the pool return run ( the run that feeds water to pool).
This will insure that when the pump shuts down, no matter which position the valve actuators may be set, water can not back feed through the pump circuit from spa to pool.
Posted on Aug 23, 2009
  • 8404 Answers
SOURCE: must pool and spa have equal HP pump.
No 1 hp each is plenty for each
Posted on Oct 20, 2009
macdirk
  • 116 Answers
SOURCE: Need to replace pump Impeller on A.O. Smith
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 12, 2010
Pure Spa. where can I get an owner's manual?
Support - Intex
www.intexcorp.com/support/
The leader in Above Ground Pools, Airbeds and Inflatable Spas. ... Manual Pumps · Electric Pumps · Parts & Accessories · Electric Pumps · Floats & Toys · Pool Toys... If you don't find what you're looking for, get in touch with Customer Service.
2500 Gal Filter Pump (120v) - Intex
www.intexcorp.com/28633eg.html
Review the Trouble Shooting Guide in your Owner's Manual. Are any tools ... Can we use the pool while the filter pump is operating? Is it safe? No, due to ...
Oct 28, 2015 | Intex Pool & Spa
How do you fix error code E90 in my intex spure spa pump?
You have an owners manual I hope, with
the codes & trouble charts
I would say call the pool & spa store & have
someone trouble shoot the problem
Nov 10, 2014 | Pool & Spa
Spa will not get up to temp I set it to 103 and it only gets to 91
Go to a Pool & Spa Store & take your
owners manual, etc & discuss it there
91 may be a default setting when the pump is off
& it is not used,so you may have a problem
Nov 06, 2014 | Pool & Spa
Capacitor type
take capacitor to electric supply store to match up
Apr 20, 2012 | Century New Magnetek Pool Spa Pump Motor...
Pentair superflo electrical wiring
if 220 volts 2 blues 1 to L1 one to L2 green to ground or case
Feb 08, 2012 | Pentair Super Flo 1 Hp Pool Pump 340038
Aug 09, 2009 | AO Smith Pool Pump Motor Hayward 2 Speed...
I have an A.O.Smith Century Pool & Spa motor 1081 pool pump duty 1.5 HP. It is making a very loud noise, do you think it needs replacement or should I look for something else?
Jun 19, 2009 | Hayward 1.5hp Pool Pump Motor Motor A O...
Pool & Spa Logo
99 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
