Question about Panasonic SC-HT920 System
SC-HT920 - Says INIT and cannot perform functions requested
My darling sons put 2 magnetic clips, that hold our entertainment unit doors close, into the DVD player. We didn't realize this until I went to take it apart to figure out why the only DVD in there wasn't working and heard them moving around. Before taking the player apart, it would say "Hello" on the display and then "INIT", followed by "Please Wait". If you asked it to OPEN, it would make a little noise and then stop and the display would read "Open". The same with closed. It wouldn't recognize the disc in the No. 1 spot (saying "No Disc) and wouldn't move to any other spots to read discs. When I took the cover off and extracted the DVD, I noticed that the clips were dropped under in the DVD reading area. I had to take the top portion of the turn plate (the part the holds and spins the DVDs) off in order to get the clips out. I put it all back together and tried to get it to aleast open, but it would just read the same display as before. Then I noticed that it wouldn't even say "No Disc" when requested to scan the No.1 spot. It still won't move to other disc spots and doesn't read "Closed" when requested it to open and close (which it still doesn't do). I took it apart again to see if I could notice anything broken or odd to me, and I couldn't. I played with the power while I had it apart and noticed that all the machine does is move this rectangular piece (located under the area the DVD is to be read and set back a bit from the actual reader, I could only see it with the DVD turntable taken out) a tiny bit forward and back, though it has more distance to move than it actually does. I assume it's involed with helping the gears to open and close the unit and turn the DVDs to access the requested DVD. What I am wondering is whether my DVD player is done for good or is it fixable. If it is fixable, what may be the problem and possible cost to fix it. Any help or suggestions would be greatly appreciated. I know my unit is 4 years old, but I've enjoyed it and would love to be able to keep using it!!
Thanks in advance,
mehopes
4 Suggested Answers
furion187
  • 54 Answers
SOURCE: dvd tray will not open
Sounds like it's jammed it self up, if you got finger nails try pulling the front on the dvd drive as you push the open button, otherwise look for a little tool of some sort to wedge in the front of the dvd drive to give it alittle movement as you press the open button, it may need a bit, just be careful not to break it lol , if still no luck unscrew the sides and back if it has screws at the back , lift the top off , and push the dvd drive from in there , that will atleast get the disk out, and lets hope solve future problems ,
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: Unit says Init Please Wait
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Posted on Apr 14, 2008
SOURCE: panasonic sc-pt1050 just displays close
I have the same exact problem. Turns out my toddler has stuck a piece of paper in the tray, so the tray was just stuck. I just undo the four screws on the side and 3 in the back, lifted up the top cover, remove the paper causing the jam, put everything back together. Problem solved. Saved $140 from having to sent it to Panasonic
Posted on Aug 07, 2010
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
My philips dvdr3510v player is not opening tray its saying blocked how do i solve the problem
This seems to be a manufacturing problem. When the disk is loaded it is centered on a spindle and to make sure that centering succeeds a magnet mounted to a small white rotating plastic piece on the top of the DVD drive. The magnet seems to bee too strong on my machine so the spindle isn't able to disengage when trying to open the tray. The result is blocking. It is of course possible that the electric motor moving the tray and the spindle movement is too weak. Anyhow this is how I solved the problem on my Philips Video/DVS DVDR3510V:
1) Disconnect the device from mains power.
2) Unscrew the eight screws holding the top in place.
3) Unscew four black screws keeping the DVD unit fixed to the main body.
4) Carefully drag the DVD slightly back which allows you to rotate it to point sideways (this allows simpler testing of the mechanical working).
5) Unscew the two blank screws keeping the front half of the top of the DVD unit in place.
6) Using a small screw driver carefully bend the clips to allow the top plate to be removed.
7) Connect the mains power and don't ouch anything inside.
8) After startup try Eject/Load several times to ensure that the DVD unit is mechanically working OK. If the Eject/Load doesnt work with the top off there is no use going further.
9) Disconnect mains power.
10) Use a small felt tipped pen to mark the face of the small metallic (magnet) part in the center of the white movable component fixed to the top.
11) Using a small flat screw driver carefully open the clips holding the two halves of the white component together. Careful! The clips may break easily.
12) Cut small pieces of tape (or use thick drawing paper). The idea is to lift the magnet slightly upwards. We thus use tape or paper as shims. Notice that a hole is needed in the center.
13) When the shims are in place put the magnet back oriented correctly (if you didn't mark it test it against the spindle rotating the disk. The correct orientation is where the magnetic force is strong.
14) Mount the halves back into the hole in the top component and align the clips. Then press the halves together until the clips connect.
15) Put the top component back and clip it into place. No need to screw in the screws yet.
16) Connect mains power, don't touch anything inside.
17) Check that the tray now opens both with a disk and when empty. Check that a DVD is recognized correctly (too little pressure leads to disk loading failure).
18) If the DVD unit now works assemble it and you are done.
The first picture shows the white round plastic part that is modified on the left hand side of picture.
The second picture shows an additional support I glued to the top with super glue because the top is fairly flexible. Initially I thought this was the reason why the spindle got stuck. I think the extra support is unnecessary but i didn't bother with removing it.
Dec 29, 2010 | Cameras
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Dvd door keeps opening on toshiba rd-85dt
same problem i had, there is a small microswitch under the top left corner of the dvd door, the microswitch is broken, it breaks if you put stuff on top the unit and move it about, it catches the door and breaks the end of the switch, easy fix for average electronics enthusiast
Jan 23, 2010 | Toshiba RD-XS52 DVD Recorder
Cannot eject upside down DVD
There should be a small hole somewhere in the front of the player on or very close to the door. This is an "emergency" door latch.
If you straighten out a paper clip, you can (WITH THE POWER OFF) insert the end of the paper clip into the hole. Just inside the hole, you will feel the clip stop (about 1/2 inch). press slightly on the paper clip, and you will over ride the door latch.
If you have any doubts about doing this, contact the manufacturer first.
Joe
Dec 26, 2009 | Delphi Car Audio & Video
The door/tray will not open.
Press the open button, and quickly lift the unit 1 inch and drop it. This overcomes the strength of the magnet and allows the door to open.
Jan 20, 2008 | RCA DRC8300N DVD Recorder/VCR
Disc door will not open
Open the unit and remove the DVD manually. The magnet that holds the DVD in place is stuck to the top cover.
Nov 29, 2007 | Lite On LVW-5005 DVD Recorder
Eject tray belt broke
Opening the DVD player tray is not as hard as you would think.
1. Remove three black screws holding the outer cover on the unit (located on rear of unit)
2. Carefully remove front panel trim by gently prying six clips (3 on top, 3 on bottom) away from unit and pulling panel away from unit.
3. Locate opening at the front of the DVD player that houses a larger white gear.
4. Using a finger, gently move gear until DVD tray begins to move outward.
5. Continue until DVD is fully ejected.
6. Try plugging the unit back into AC outlet and attempt to Open/Close the tray using the provided button on the Front Panel Circuit Board.
7. Reverse steps above to put unit back together.
Nov 27, 2007 | Sony SLV-D350P DVD Player/VCR
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
Panasonic SC-HT920 System Logo
157 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
