Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mitsubishi 62825 flashing green light on timer set wont come on,try reset same problem ?
  • 1 more comment
  • rossnotes Jan 21, 2009
    I have the same problem. Whenever I get a power interuption my TV flashes green light (I have a high dollar surge protector) and will not reset with the the reset button or power button. I have usually been able to unplug the tv for 60 seconds then turn on the TV and it would reset in 60 seconds. Now it does not reset. I have tried every combination of pushing the button, unplug, turn off ect...basically the green light just flashes.
  • bborton23 Feb 26, 2009
    I have the same problem the green light just keeps flashing. What is wrong?
  • Anonymous Apr 02, 2009
  • 38 Answers
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor, T.O., Ca
Posted on Mar 13, 2009
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Green timer light wont go away
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
We have a Mitsubishi DLP and the timer light is flashing on and off and I cannot turn the power on or off on the TV
Bad signal board, DM module and or formatter board. Try replacing the signal board first. About 50% of my fixes with flashing timer LED was solved by signal board replacement. If this doesn't work, then try replacing the formatter board. And if still don't work, then DM module must be replaced.
Mitsubishi don't have a real answer behind these failures. I know and I've tried. Do have two of them just came in my possesion for repairs. One has same problem and just put in order for new signal module.
Nov 27, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Green timer light
I have the same problem with the green flashing light. We have had the chassis rebuilt by Mitsubishi which took 41/2 months to get done. Now i am told after it went out again that it will take the same amount of time. By the way the TV only worked for about 90 days after they rebuilt the chassis. I am going to push for Mitsubishi to replace this as this has happened twice now. and for those of you who own this TV they are not cheap. I will keep you posted with what happens. or if I own a 5000.00 paper weight.
Apr 24, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Green timer light
check the number of blinks each blink means something
Apr 19, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto get error codes first and get back with me.
Dec 17, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
268 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
