Question about Dell UltraSharp 2009W LCD Monitor
Dell 2009w goes to sleep mode within 3 seconds of turning it on
On for 3 seconds goes black. no wake up.
  • 4090 Answers
SOURCE: Problem w/Dell E176FPf monitor stuck in power save mode
Ok if it the monitor works fine on another unit discount it out of the equation as a monitor problem.
I would suspect the driver on the PC that delivers the problem, especially the video card.
. Check that the cable is also on tightly. remove it and even clean the pins and replug it .the plug on that PC may be dirty
You May need to replace the video card as the communication to the monitor is intermittent and that is why you get the amber light.
Open the box with power off. clean the card if it has a lot of dust on it ( most do and its always a shock) wipe it over ( BOTH SIDES) and then try to start it up as usual with the monitor connected to see if that fixed it ( sometimes works) if not get another card and replace it. Best I can offer without being there to help on the spot.
A new card should allow you access to install and configure it and these days they are pretty cheap to buy
Please rate this help to keep the service online
Posted on Aug 20, 2009
budmrtn
  • 11361 Answers
SOURCE: my dell monitor turns on for 2 seconds then goes
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdreapir.us
Posted on May 16, 2010
  • 732 Answers
SOURCE: dell E228WFP monitor cutting off, goes black
sysjrm, You need to visit YOUTUBE for video clips of "lcd monitor repair" to see if DIY project is what you can handle!!! After you "learn by seeing" some printed circuit "switch-mode-power-supply/inverter boards" having their "aluminum-can" electrolytic filter capacitors replaced and/or "thermally-intermittant" fractured solder-joints "resoldered" then you will be able to make decision on what to do about attempting a repair to your E228WFP! Note!!!! Make certain that your pc is not the cause of your BLACK SCREEN or BLACKnBLANK SCREEN problem/symptom by connecting a "known-good" monitor to your pc first!!! Please read the higher numbered(32 and up) pages in my fixya profile for more information on how to do the simple "flashlight test" for evaluating the state of shutdown that the switch-mode-supply may be in. Also read and follow the links you find in the profiles of "budmrtn" and "buddymc" that are very good ccfl back-lit lcd monitor technicians here on fixya. After you do your web research, remember to come back to this posting and do a comment and rating of this response if you feel that it has steered you in the right direction. Good luck with the repair. 12fixlouie
Posted on Jul 23, 2010
budmrtn
  • 11361 Answers
SOURCE: 17 inch E171FP monitor (Dell)
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Aug 29, 2010
budmrtn
  • 11361 Answers
SOURCE: lcd monitor Dell model E193FPc
Look for bad caps and shorted out transisotrs in the power supply/inverter board: http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
Posted on Aug 31, 2010
Laserjet 1536dnf mfp not waking out of sleep mode
Disable sleep mode or update firmware. Cause this is a firmware bug.
Nov 13, 2013 | HP Laserjet M2727nf Multifunction Printer
Dell inspiron 1545 goes to sleep while in use
The solutn is...please uninstall..the AHCL driver from ur pc..then the problm is solve...try it...thank u..
Mar 26, 2013 | Dell Inspiron 1545 Notebook
After shutting down the Vostro 200 slim tower the power button turns from blue to amber and stays that way. I have to push the power button down for a few seconds to fully shut down. any idea why it does...
IT IS SLEEP MODE AND YOU HAVENT SET ANY DEVICES TO WAKE IT UP.JUST FIGURE OUT HOWE TO SET DEVICES TO WAKE FROM SLEEP OR CHANGE SLEEP TO ANOTHER SETTING .JUST GOOGLE IT AND YOU WILL FIND THE ANSWER YOU ARE LOOKING FOR.
Jun 27, 2012 | Dell Vostro 200 Desktop Computer
Iphone in recovery mode
1. Launch iTunes and connect the iPhone to your PC or Mac.
2. Press and hold the Home button and the "Sleep/Wake" button (located at top left corner of the phone's body) at the same time.
3. As the screen turns Black, release the "Sleep/Wake" button while still holding the home button, until iTunes displays a message telling you that it has detected an iPhone in "Recovery Mode."
Sep 27, 2011 | Computers & Internet
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 13, 2011 | Dell Studio 1537 Laptop
My phone can't connect internet
Your phone might be having some connection problems restarting it should fix it here are some different ways to restart the phone if it still does not work with one way try the other:(It can also be relate to your network maybe low signal or no reception at all)
Reboot:
1) Turn on iPhone.
2) Hold Sleep/Wake button (top right) until a red slider appears and says Slide to Power Off.
3) Slide the red slider.
4) Once the chasing lines are gone and the screen is black, hold the Sleep/Wake button for about 2 seconds. Your iPhone is now rebooting.
Hard Reset:
1) Power iPhone on.
2) Hold the Home and Sleep/Wake buttons for about 7 seconds, or until the screen turns black.
3) Your iPhone should reboot. If it doesn't don't worry, just hold the Sleep/Wake button for about 2 seconds.
Restore:
1) Connect to iTunes.
2) Allow your iPhone to back up and finish the sync.
3) In the Summary tab, click the Restore button.
4) Click Restore and Update to the confirmation message that appears.
5) Follow on-screen instructions from there on.
Feb 26, 2011 | Apple iPhone Apps
Hi to all, can you help me guys, i am having a problem with my Lcd monitor AOCTFT1560ps, my screen turns black after a few seconds and my OSD was locked..... HELP ME GUYS!! thanks
This link may help. You can try to do something if it is connected to a computer. If not, you can disconnect the video cable from both end and wait for 5 minutes and reconnect it. After your monitor wake up, use your OSD to disable sleeping mode, hiberation mode or turn off monitor mode within power options.
Nov 03, 2010 | Computers & Internet
The power button keeps blinking every 2-3 seconds and the screen is black and wont turn on
It sounds like it is in "sleep mode"
Try pressing any key on the keyboard and see if it wakes up.
Nov 04, 2009 | Gateway HD1900 19" Monitor
My phone goes to a sleep mode and refuses to wake up.
Mine does that sometimes too. If you just press and hold the button for about 3 seconds, it will turn on within 15 seconds.
Apr 01, 2009 | Samsung Omnia Cell Phone
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
Dell UltraSharp 2009W LCD Monitor Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
