Question about Compaq Armada E500 Notebook
No power on
When the power botton is preesed it is not display any thing, onle achrger indicator is blink.
  • 70 Answers
Waht happen if u press on buton, u should mention.if nothing u should check for adaptor, ur battery may be low so its battery indicator is blinking.
Posted on Aug 23, 2009
Maruti/ertiga how to set clock.there is no any botton to set the clock
How to set Clock When the ignition switch is in the "ON" position, the display (D) shows the time. 2) To change the hour indication, turn the indicator selector knob (2) left or right repeatedly when the hour indication blinks. To change the hour indication quickly, turn and hold the indicator selector knob (2). To set the hour indi- cation, push the indicator selector knob (2) and the minute indication will blink. 3) To change the minute indication, turn the indicator selector knob (2) left or right repeatedly when the minute indication blinks. To change the minute indication quickly, turn and hold the indicator selector knob (2). To set the minute indication, push the indicator selector knob (2). To change the time indication: 1) Push the trip meter selector knob (1) and the indicator selector knob (2) together. w WARNING If you attempt to adjust the display while driving, you could lose control of the vehicle. Do not attempt to adjust the display while driving.
Hope this helps.
Bob
Feb 08, 2015 | Cars & Trucks
My sony 21 kv21da55 no power on blinks red lights 10 times or more times pressing the channels botton repeatedly powers it on
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Schematics too are given.
Sep 18, 2014 | Televison & Video
How can i solve my sony ericsson k610i power on problem,when i press power botton onle red led blinking
Hi Dear
Actually this problem is you mobile OS, please update your reinstall the OS through the software. see the attached video and flash you OS and install again.
For supporting software click hear
Cheer
Jul 27, 2011 | Sony Ericsson K610i Cellular Phone
The power botton indicator blinking amber light and if i pree any key the system comes up
You're going into sleep/hibernate mode.
Simply go to start menu, control panels, power options to change the time before this occurs, or to switch it off.
Aug 19, 2010 | Computers & Internet
The power indicator on my dell d430 is blinking yellow and green. It works fine but someone told me that the CMOS battery is gone. Where is it located
Could be a number of things, the Cmos battery is unlikely however, as that merely maintains the date and time settings. You'll find the battery under the case at the botton of the laptop .
The blinking yellow / green lighst point to a faulty power supply, which may be failing. I'd have this tested firts to see it is putting out the correct voltage before opening the case. If it is working and charging the battery, then the issue might lie within the motherboard itself. Do you get any other issues with this such as Bios beeps on start up?
Feb 11, 2010 | Dell Latitude D430 Notebook
I have 4 32" Sony triton TV's that turn on and off
I think problem in power supply section and it would be nice if you could provide exact model number of your Sony TVs, question headings show it is KV-32FS120 TV, please confirm to proceed further.
Thanks.
Sep 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
No LCD Display, Does not Boot
I would check the power adapter with a multimeter first thing.
Nov 12, 2007 | IBM ThinkPad T23 2647 Notebook
Compaq Armada E500 Notebook Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
