Question about Garden
Viper premium pressure washer 2500PSI 5.5HP - Garden
3 Suggested Answers
wmpcs
  • 100 Answers
SOURCE: My 2500psi power washer takes
See attached link, follow the instructions, this should fix your problem.
http://www.wmpcs.com/blog/?p=72
Posted on Oct 28, 2010
Testimonial: " I believe the stock loader was an engineer slip up from the beginning.This should resolve my problem. Thanks "
  • 202 Answers
SOURCE: NO PRESSURE
check the coupling or the belt between the engine and pump. unsure which this washer uses. the pump may also have failed, usually it is the coupling or belt broken or slipping
Posted on Jul 09, 2009
Kingwash water blaster instructions
what do you wanna know?
not much information needed to run
Apr 06, 2014 | Garden
The chemical injection system on my craftsman 2500psi washer will not inject cleaner through the wand. have cleaned all parts and still won't work
The chemical injection system works by siphon action. You must have the black or largest/ low pressure tip installed for it to work properly. If you feel any pressure at the wand, most likely will not work. If your wand has the adjustable type tip, it may have a restriction causing pressure and not allowing siphon action. If you continue having trouble with siphon, you could plug/shut of siphon and install an aftermarket injector between the wand and the pump (not expensive). Sold at www.pwmall.com Good luck
Jul 01, 2011 | Karcher 2500 PSI Pressure Washer
My 2500psi pump leaks what can i do?
sounds like the seals and o'rings are worn and causing the pump to leak water.also one of the pistons might have a crack in them.dis assemble the pump and inspect the pistons,if none are cracked,then replace all the o'rings and seals.this should stop the pump from leaking.
Jan 15, 2011 | Honda Pressure Washer PSI 3000
My Troy Built 2500psi washer will not pump cleaning solution.
Next problem will be the spray head itself. It needs to be cleaned with a small wire from time to time.
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
NO PRESSURE
Jul 09, 2009 | Briggs & Stratton Garden
Garden Logo
357 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
