Question about ASUS VW192TG LCD Monitor
Asus VW192 19'' monitor stretches the picture
People look short and fat on my new 19'' asus monitor.  I didn't get a user's guide and I need help.
Thanks
  • Anonymous Mar 26, 2014
    monitor isn't showing all of the picture on the smartboard
Have you set the resolution to the max of the monitor? 19 inchers usually need 1440x900.
to do so go to control panel and display properties then slide the slider to the max, apply and exit.
hope that helps
Posted on Jan 21, 2009
How to increase volume on monitor. on monitor the volume shows in minus. hot to bring it to +. no sound is coming at all.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.asus.com/us/Commercial-Monitors/VE208T
Asus VE208T User Guide
Mar 19, 2016 | ASUS VE208T 20 inch LCD Monitor
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I have a new Acer X203H 20" wide computer monitor. All of my photos are streched wide, and everyone looks fat. Can I adjust this ?
You need to set the PC video resolution to 1600 x 900 for proper 16:9 wide screen format. But if your pictures that you taken with your camera were not 16:9, IE 4 X 5 then it will be stretched side way to fill the screen.
Jan 07, 2010 | Acer X203H bd Monitor
Will not let me update driver for VGA connection
Hi there, welcome to fix ya.
Have you tried updating your mobo/chipset drivers?
Tim
Aug 28, 2009 | ASUS LCD Monitor
Need a user guide
Hi
heres the English manual for you.
http://ekse.hopto.org/FixyaSupport/English.pdf
Good choise, I have two of the VW series and one of the PG series of asus monitors myself, all doing great so far, the PG is atleast 2 years old soon, others are around one year.
no problems yet I hope these work long.
Thanks and good luck with the monitor!
Ekse
May 30, 2009 | ASUS VK222H Monitor
Wide screen problem
Try adjusting the setting of the video card instead. right click on the desktop and select properties and setting. select the screen resulution that fits your monitor.
Most monitors are plug and play and does not need a driver.
Mar 29, 2009 | ASUS VW192S Monitor
Pictures are stretched
change the screen resolution to different proportions, sounds like you may have set to 1208 x 768 a more appropriate setting would be 1024 x 768 however switch between the different settings until you find one you like
Dec 30, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Bought new monitor Asus VW193T help to find driver
change your resolution in display properties.
Dec 26, 2008 | ASUS VW193T Monitor
Monitor installtion
Hi Robin,
Hope this instruction well do solve like I met some problem like this. Try to reset the monitors setting manually in OSD (on screen display) mode. Look for frequency settings start at lower and have test it all. Respectively try to configure the video card frequency settings at Operating System GUID (Graphics user interface display) video card setting properties. Start from lower frequency and notice the each changes. When perfectly proportionate select Apply settings.
Best regards,
Rosener Guyano
Nov 13, 2007 | ASUS VW192S Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
ASUS VW192TG  LCD Monitor Logo
792 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
