Question about Murano Watches
Murano watch band adjustment
Style number 83037tc
  • 8 Answers
SOURCE: seiko watch band
very tightly
Posted on Jan 02, 2008
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Posted on Feb 09, 2008
slp11508
  • 43 Answers
SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
Band replacement for watch e15008g1?
  1. Watch Band Replacement - MVMTwatches.com‎
    Adwww.mvmtwatches.com/Watch-Straps‎rating for mvmtwatches.com
    It's Time To Switch Up Your Look. Interchangeable Straps Are Here.
    Free Shipping Worldwide · Free & Easy Returns · Lifestyle Timepieces
Search Results
    Amazon Best Sellers: Best Watch Bands - Amazon.com
    www.amazon.com/...Watches-Watch-Bands/.../watche...
    Amazon.com, Inc.Discover the best Watch Bands in Best Sellers. Find the ... Apple Watch Band,Teslasz® 38mm Mesh R... 3.9 out of 5 ... Luminox Replacement Band ES for 3050.
    Watch Bands - Overstock Shopping - The Best Prices Online
Jan 16, 2016 | Watches
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    How do I adjust the band
    If it has a clip-style wrist attatchment, you may slightly adjust the pins a couple of inches with a small pin to remove thte sppring and re-insert in another hole. I recommend tweezers and a clean work surface. The spring MAY fly, so ask someone to hold their hands over the area you are working on. If you need more adjustment, go to a jeweler to have links removed /added.
    Feb 17, 2010 | Citizen Cortina Eco-Drive BM8194-50L Wrist...
    I would like to Identify this watch and its value. It has two seperate letter / # combos on the back. BVLGARI - AL38A, L3276
    This is a Bulgari watch (Printed BvGari) model number AL 38 A.
    An authentic Bulgari watch of this style would sell for around $2000. This particular model was counterfeited a lot so its best to have a watch maker familiar with the model or brand look at the case, band, and movement. Be sure to have the movement inspected so you know it was not swapped for a cheap replacement.
    Sep 18, 2009 | Bvlgari Watches
    Murano bracelet watch lost 2, small white beads & looks lopsided
    Wonderful company I bought Murano Millefiori watch from here in USA is replacing for me per today's e-mail which came same morning as your.
    This site is very interesting and will keep it for futher use!
    Thank you for wanting to help me!!
    Debbie
    May 16, 2009 | Murano Millefiori Firenze Bracelet Watch
    Watch bands f/ Kenneth Cole
    Replacement watch band (f) can be purchased from amazon, take a look here: Amazon com kenneth cole band Watches Women Clothing Shoes Jewelry Wish you best of luck. Cheers
    Jun 22, 2008 | Watches
    Item number L12445 band adjustment
    How do I shorten the links on a woman's eco drive citizens watch band?
    Apr 22, 2008 | Watches
    Watches Logo
    Top Murano Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Murano Watch Expert? Answer questions, earn points and help others
