Question about Microsoft Xbox 360 Console
AC power adapter light is red what to do?
Last night i was playing my xbox 360 it was fine but when i tried to turn it on in the morning the AC power adapter light was red so i cant play my xbox now.
The power supply is already busted
you need to call xbox 18004699269
if you purchased the xbox within 90 days, then they can have your power supply replaced
if not you need to buy a new one
Posted on Jan 19, 2009
I played like 30 min then i went out and when i came back home at the night i couldnt turn my xbox360 ellite on and the ac adapter was blinking orange!
It sounds like your power brink may have over heated or faulted. Please see this page for information.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Aug 18, 2011 | Microsoft Xbox 360 Console
When my Xbox 360 is off, the light on the AC Adapter is orange, but when I hit the power button to turn the Xbox 360 on, the light on the AC Adapter turned red.
HI you did not mention is you are able to use the unit even tho the led turns red. If not then the unit is drawing to much current and the power supply is shutting down. Or the power supply is faulty, If you can and know someone with a 360 system try to borrow theirs and see which part of the system is faulty if you know his is good and the same thing happens, or take yours to his house and try, but if same results then the 360 is at fault.
Apr 21, 2010 | Microsoft Wireless Network Adapter Xbox...
Last night I had 3 lights come up on the xbox within 10 minutes of play...this morning I checked it and all was normal but have not tried to play it yet. what does this mean? Most of what I have read the 3...
The 3 red lights is a hardware problem. At first it can be intermittent. When my first xbox got the red lights. It did it once, then the next 2 days was fine, then it did it again. Eventually it will get worse and no longer work at all. Contact Microsoft to see if the unit is still under warranty.
Dec 18, 2009 | Microsoft Xbox 360 Console
My xbox 360 works fine playing the games that are demos
there might be a short.
other then that i might just think that your power adapter is failing and you need another one.
Dec 01, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
I play for +- 30 min and the powersupply goes on red is it the powersupply or the box
If you are getting a red light on the Xbox 360 power brick, That happens when the power supply gets to hot or its not getting enough juice. Try plugging it in somewhere else and see if that helps, and make sure not to use any UPS, surge protectors or power strips to plug in your AC adapter
also check if the power connector is firmly connected or not behind your xbox 360, if you still have a problem, check if you can borrow another Xbox 360 from anyone you know and swap the adapter and console which would help you know where the problem is
If none of this works, call up Microsoft for further help and support, since your problem may require servicing of your console.
If you are getting a Red Ring of light on the Xbox 360 power button, please clarify since it requires separate diagnostics.
Hope you get back to gaming on your Xbox 360 ASAP
Dec 01, 2009 | Microsoft Xbox 360 Console
AC Adapter on !ORIGINAL! XBOX (not 360)
this could be the case if you need to replace the ac adapter its called a figer of eight mains lead, but the problem could be something Else if you have lots of plugs on one socket this could case a problem with a short surge ruining to the xbox and popping the red button out try using the box on one power point on its own with nothing Else even if this means running an extension cable from the hallway or kitchen, if it pops again then look at the mains lead. if it does not pop is ur power point (plug/s where you have the xbox pluged in). i hope this help cheers
Feb 06, 2009 | Microsoft Xbox Console
Two left red lights
The two red lights is usually over heating. Make sure it has good ventilation and that the fan is working in the back. Let it cool down for a couple hours and try it again
Oct 30, 2008 | Microsoft Xbox 360 Console
Sound quits after game loads.
are you using original xbox games or 360 games
Dec 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
470 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
