Question about Hitachi Mht X750 750 Gb External Black Usb20 25inch Max Data Transfer Rate 60 Mbps USB 20 Hard Drive
Unable to format hitachi x750 drive for mac - Hitachi Mht X750 750 Gb External Black Usb20 25inch Max Data Transfer Rate 60 Mbps USB 20 Hard Drive
2 Suggested Answers
  • 825 Answers
SOURCE: Hitachi ext. drive formatted for a PC, but now I want to read it
you need to reformat the drive for MAC...
Use Disk Utility To completely erase a Macintosh hard drive that runs OS X 10.3.x or above—not just individual files on the drive—you can use the Disk Utility that is built into the Macintosh operating system.
How to Use Disk Utility to Erase a Macintosh Hard Drive (OS X 10.3.x or 10.4.x)
  1. You must reboot your computer using the OS X system CD that came with your Macintosh. To do so, follow these steps:
  • Insert the CD into the CD drive.
  • Hold down the C key during the startup process.
  1. Select your preferred language. You will then see the Welcome to the Mac OS X Installer window.
  2. From the Installer Menu Bar, click Open Disk Utility. You will then see the Disk Utility window.
  3. In the left pane of the Disk Utility window, click the drive you want to erase.
  4. In the right pane of the Disk Utility window, click the Erase tab.
  5. From the Volume Format drop-down menu, select Mac OS Extended (Journaled).
  6. In the Name field, highlight the existing text and type the name the hard drive is to be called after it's formatted.
  7. NOTE: If you ever plan to connect another computer running OS 9 to this hard drive, you'll want to install the Mac OS 9 disk driver, so that this disk will be visible from an OS 9-booted computer. If you don't know if you will do this in the future, it's best to install these drivers.
  8. The following are the available security options:
  • Don't Erase Data—This option only rewrites the headers on the disk. Files can be recovered by forensics, disk utilities, and other advanced recovery software.
  • Zero Out Data—There are forensics utilities that, albeit expensive and time consuming, can retrieve zeroed-out data.
  • 7-Pass Erase—This is considered sufficient by government standards to erase data from a disk. It writes random data over the disk seven times. It may take several hours or more to complete this process.
  • 35-Pass Erase—This makes it absolutely impossible to regain any data off the drive. This option takes an extremely long time, possibly more than one day.
  1. Click the radio button in front of 7-Pass Erase (recommended by UD).
  2. Click OK.
  3. Click Erase.
  4. Confirm you want to erase. The program will unmount the volume, partition the drive, and rename the volume to the name you typed in step #7 above.
Posted on May 19, 2010
Unable to read external HDD after plugging it to a Mac (previously it is readable via a Windows PC)
Chances are it was formatted as NTFS format by the PC which is not MAC compatible. You will need to reformat the drive in HFS format if you want it to work as a MAC disk only or in FAT32 format if you want to read it in PC and MAC machines.
Jul 24, 2014 | Western Digital WDG1C2500N MyBook Premium...
Mac hard drive replacement
Most hard drives would be fine for your mac. It's just the formatting needs to be suited for your mac. For laptops you will need to get a 2.5" hard disk but just mimic the HDD size of the original.
Oct 31, 2012 | Hitachi Computers & Internet
HOW TO TRANSFER DATA FROM SIMPLE TECH HARD DRIVE TO MAC
Yes Mac and Windows use 2 different and incompatible hard drive formats. However, there are many files that can be opened between the two. Mostly media and some docs. Try uploading to somewhere like MS Windows Live Skydrive or simply email. Then download. This is a quick fix. I heard you could use file sharing, but that requires a network. Even burning to a disc should work.
Aug 31, 2012 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
Unable to move files from my mac to a external mac formatted usb storage drive
I believe the Belkin N750 is not compatible with Mac-formatted drives. I run Macs and while my N750 will see the drive, it is treated as read-only. Try reformatting in FAT-16, FAT-32 or NTFS.
Jun 27, 2012 | Belkin Computers & Internet
External hard drive used on mac,how do i use it on pc?
You need to format this hard drive using your PC.
If the hard drive was formatted using the MAC then the PC won't see anything on the hard drive because the MAC uses a different file system that is not compatible with the PC.
BUT if you want to exchange files between the MAC and the PC then format the hard drive using the PC in FAT32 file system. The MAC can read and write to a FAT32 formatted hard drive.
Apr 10, 2012 | Hitachi Computers & Internet
Macbook pro os x 10.4.11 won't recognize or mount my new Hitachi xl3000
The Hitachi XL3000 is formatted for the PC, but your Mac should recognize it. Try another cable or port. Check in Disk Utility to see if the drive appears. If it does, then you can format it for the Mac. You can do this in Disk Utility by clicking on the hard drive on the left side of the window. Then choose the Partition Tab, and change the Volume Scheme drop-down menu to 1 Partition. Then click on the Option button, choose GUID partition map, and click OK. Then choose Mac OS Extended (Journaled) for the format and click Apply and OK. Your drive should then format for Mac and mount on the desktop. If it does not appear in Disk Utility after changing the cable and port, or trying another computer, then you may need to return it for replacement. I hope this helps.
Sep 11, 2011 | Hitachi Retail Xl Desk Xl3000 3 Tb...
My macbook pro running leopard 10.5.8 will not recognise my hitachi 320gb external hard drive
Find the drive and make sure it is formatted as a FAT32 drive. Mac computers only recognize drives in that format. If it can't be seen at all, try plugging it into a PC and then formatting it as FAT32. It should then be recognized by a Mac computer.
Mar 08, 2011 | Computers & Internet
What is the formatting an a hitachi pro1000q
If the hard drive comes directly from the manufacturer or retailer in a sealed box, it is in RAW format. If you want to use it on a MAC, it has to be formatted FAT32, if you want to use it in a PC, then the usual format is NTFS.
Jun 28, 2010 | Hitachi Computers & Internet
Worked fine on my macbook but not by my powerbook g4 or any other computer
I would suspect a corrupted catalog file, these are the map that a comupter uses to find its way around the drive, they are also the first casualty when a crash corrupts something. Disc warrior will write a new catalog and fix everything. PCs do not see discs formatted for macs.
Aug 21, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Hitachi Mht X750 750 Gb External Black Usb20 25inch Max Data Transfer Rate 60 Mbps USB 20 Hard Drive Logo
23 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
