Question about Bosch Dishwasher Control Panel Cover Facia- 431828
Replace control panel bosch dishwasher she55 - Bosch Dishwasher Control Panel Cover Facia- 431828
textonor
  • 130 Answers
SOURCE: Bosch dishwasher
1st pull the 6 screws holding on the outer door panel. Then the 4 screws you already did. Look now at the side of the inner door at the top and you will see 1 screw on each side. Remove these and the panel will fall off.
Posted on Mar 16, 2008
  • 6 Answers
SOURCE: bosch dishwasher just keeps going and going
be shure its not under the rework
Posted on May 04, 2009
  • 246 Answers
SOURCE: Need to change color of front of dishwasher
Try Applianceart.com. They have a ton of options in colors and desings
Posted on Jan 14, 2010
marka19
  • 1430 Answers
SOURCE: my Bosch dishwasher (shu30) sticks in the rinse
Not sure why you would want to remove the panel? When this problem occurs First try putting in diagnostic mode and going thru the cycles. Anyway the tech sheet will be located behind the panel this will walk you thru putting in diagnostic mode.
There is a series of 4 screws that hold the top portion on. These are located on the inside of the door and require a torx bit to remove. Remove the screws and then lift up and out on the cover to remove. There is not a lot of wire there so I usuall remove the lower panel also,same procedure just remove the screws and slide down slightly to remove this panel. You will have to plastic pcs that slip over the hinges at the bottom and these may fall off when removing the panel. To reassemble put lower panel on first and leave the top two screws out until the control portion is installed then put in the rest of the screws.
Posted on Mar 24, 2010
Macmarkus
  • 2605 Answers
SOURCE: Fon the dishwasher
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
Posted on Jul 08, 2010
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
The start button will not stay pushed in
Hi
The start button, tends to fail on some Bosch Dishwasher models. The spring mechanism fails.
You can order the ON/OFF switch and replace it.
You need to disconnect the machine from its power source and open the control panel via hex screws. You may also need to open the front panel screws to get the top panel off.
Bosch dishwashers can be tricky and when you open the panel you many need to undo some latch tabs to get to the on/off switch.
Note the wiring on the switch before replacing.
If you thinks this solutions helped, please give 4 thumbs up.
Sep 21, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch SHX99A15UC went completely dead. Circuit
no it wouldn't, this is a common failure on bosch dishwashers. you have either a bad control or a bad touch membrane. parts are fairly expensive and only way to know for sure is to replace one. I usually find that the control panel is at fault most times
Apr 23, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch dishwasher shu43c07uc/14 dead
Control is available.
There was a recall on control modual because of fire dangers.
Call and get an auth number from Bosch 800 856-9226
Apr 20, 2010 | Bosch Dishwashers
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Can i get a replacement switch for a bosch exxcel sgs45eogb56 also can you buy a new front panel .the panel that covers the control buttons , thanks
There is a wqebsite called www.appliacneart.com that makes many different options for your dishwasher replacement panels. I know they have black, white, and stainless, but they also have a ton of other options like fireplaces, and paintings. Check them out it would probably be your best bet.
Dec 02, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch Dishwasher Problem
if you remove the front panel (the 6 torx screws) and the facia panel you can access the control module. remove the module and open it up to see if you have a burn mark from the solder melting. if you do then you know to replace the control module
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher
Mar 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Bosch Dishwasher Control Panel Cover Facia- 431828 Logo
207 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
