Question about Amana 3.2 cu. ft. Top-Load Washer
REPLACE BELT ON AMANA WASHER
WHAT NEEDS TO BE REMOVE TO PUT BELT ON
  • HAWGS20 Jan 27, 2009
    I have removed the motor/pump unit from the washer. I have removed the 3 star screws from the pump housing, however the housing won't come off the motor shaft, appears to be corroded on to it. Any suggestion on how to remove???
  • Anonymous May 09, 2009
    what size 3 star wrench or driver do u need?
  • 65 Answers
REMOVE THE FOUR BOLTS HOLDING ON THE MOTOR MOUNT TO THE MILK STOOL. DISCONNECT THE DRAIN HOSES, UNPLUG THE WIRING HARNESS AND THEN ROLL THE BELT OFF THE MAIN PULLEY OF THE TRANSMISSION. FLIP MOTOR OVER AND REMOVE THE DRAIN PUMP, NOTING HOW THE BELT WAS THREADED THROUGH THE PUMP MOUNTS.
Posted on Jan 27, 2009
How do you replace the belt on amana washer lw8203w2
To replace the belt, on the very bottom of the front you will see 2 screws. Remove them and the bottom cover will come off. You can then replace the belt.
Check the belt to see if it just broke or if have a worn spot on it. If it appears like it wore in one spot then you have another problem that needs to be addressed.
Jul 01, 2014 | Washing Machines
Need to replace the main belt on the bottom of the washer. The belt goes around the drive pulley directly below the electric motor which is accessible from the front bottom access panel. The belt goes...
Unplug the motor wiring, remove the bolts holding the motor bracket (4 I think) remove the hoses from the pump and lift the motor and pump out. Remove the 3 screws on the pump and separate from the motor. Put the belt on the pulley and replace the pump. Slide the motor and pump back in with the belt attached, but don't put the 4 bolts on until you put the belt over the tub pulley. Then put them in and plug the wiring back onto the motor. That should do it!
Nov 20, 2010 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
I hear the belt floping around in my front loader washier,how do i fix it??
Get the service panel off. Then remove 4 large bolts and the washer motor and pump will come out. Put that on a work table and remove the pump.
Service Manual Amana/Speed Queen/Maytag washer
Jul 29, 2010 | Maytag SAV5710 Top Load Washer
How do I get to the belt of my amana series designer washer
.this movie will teach you how to remove and to put it back,
http://www.youtube.com/watch?v=6XIsK3W_Qcg
this web page will walk you thru how to replace the belt
http://appliancejunk.com/forums/index.php?topic=97.msg1599#msg1599
I hope this information was helpful?
I like to tank you for the oportunity you give me to serve you please if you have any question or concer please e-mail me, I will be more then happy to assist you.
Sincerely
vickygomar
Jul 25, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replace a belt on a amana dlw330raw
you flip the washer on its side
remove the screws on the side
take out the tub springs
remove the pulley
put the belt on bolt on the pulley
put the tub springs back hardest part in my opnion
replace the screws
test the washing machine
....it is no different than changing a belt on a car ....my best suggestion is that you take pictures at every step and stay organized...that way u can tell orientation of all the parts.
Dec 28, 2008 | Washing Machines
Diagram of installing belt on amana washer
show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
Nov 02, 2008 | Amana ALW480DA Top Load Washer
Removing motor to replace belt for agitator
first unplug washer then there are 4 half inch bolts on the motor holding it to the frame take those out unplug the motor harness. then twist it out you may have to take the hoses off. then there are 3 torxs screws in the pump take them out and put new belt on same way you took off and then reverse the steps and you will be ok
Jan 30, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
Oct 22, 2007 | Amana ALW480DA Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
255 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
