Question about HP Pavilion dv6000z Notebook
The screen does'nt turn on
My computer does turn on, but I can't see anything on screen and and it looks like it resets itselfe, the lights go off and then combeak on... Is it a really bad no fix problem??
  • mistic_shang Jan 19, 2009
    No is an HP, but the screen was working last nite and today in the morning it just didn't turn on
  • Anonymous Jan 20, 2009
    I have the same computer and same porblem :-( going to call tech to try to get it fixed, its 20 months old.
    Problem Solver:
  • 21 Answers
You could have a bad LCD screen. i am guessing it is a dell? you might need to contact your computer manufacturer and ask how much is a new screen?
Posted on Jan 19, 2009
  • Colton Gilbert Jan 20, 2009
    ok then you might have a bad LCD Sceen. Do you still have warrenty? if so contact your manufacturer and they will tell you to probly send it to them and they fix it and then they send it back
2006 toyota rav4 how to reset check engine light.
remove one terminal off the battery and connect it again...chk light gone.
Nov 14, 2011 | 2002 Volvo S80
Attempting to use diag. tool on my '99 ford ranger. Not getting a reading with few different tools, one shut itself off. chk. engine lgt. came on previously and i fixed problem- chk.eng.lgt. went out on...
put your key into the ignition turn it to the on position without engaging the starter wait till your gauge cluster settles and try to read the codes at this point as per on screen prompt by the reader. goodluck
Mar 10, 2011 | Ford Ranger Cars & Trucks
Laptop comes on but screen is black/blank
If you don't see anything at all and it has not been dropped or banged it maybe something as simple as the Video out selection. Look at the keyboard and locate the [FN] and the [F4](Actually look for the key with a small video screen on it which is usually the F4 on HP machines). After turning the computer on press and hold the [FN] key then press the [F4] Key. There are 3 modes programmed into the video selection. Computer monitor, Computer monitor and External Display and External Display only. What happens a lot of the time is someone may have accidentally pressed this combination of keys and the video is actually redirected to the external monitor only option. If this does not help and you can connect the computer to an external monitor and use that key combination to get the output to that screen then the problem is most likely the Back light for the monitor of the screen itself. Both can be replaced. HP can provide the back light part at a reasonable price. For the screen itself I recommend you go to someplace like E-Bay and purchase the replacement. Make sure you look at the sellers past record so you don't get taken. I DO NOT recommend using Craig's List for anything.
Feb 17, 2011 | HP Pavilion dv9000t 17" Notebook Laptop PC...
Computer works fine but has a blank screen. I have it hooked up to a monitor right now and it is fine except for the blank screen.
can you see anything on the screen at all? Look very closely at the screen from different angles under a strong light and see if you can see a faint image on it. If you do it means the back-light is not turning on which is usually a failed inverter board (cheap and easy fix). If you can't see anything at all on the screen then either the cable is not seated properly or is bad (not very common) or the screen itself went out (more expensive repair)
Feb 26, 2010 | HP Pavilion dv5-1125nr Notebook
VA1930WM monitor turns on, displays normal for one second then goes black. Then it turns on again after a minute or so for one second and goes black. This keeps repeating over and over. Is there a known...
If it was the power supply, the light would change to amber (orange) and then turn green again when it comes back on. Look closely at the screen when the it looks to turn off. See if you can still see an image. It may be hard to see, but when the backlights go bad or fail, the actual lcd screen itself still functions and you can see a very faint image. Maybe moving the mouse in circles might help you to be ablt to see. If you cant see anything at all, then it may be a bad board inside the unit.
Just a thought....
Sep 18, 2009 | Computers & Internet
Sony KV-27fs100 screen will not do anything, power is on
You may have had the sleep mode set itself. Try unplugging the set for 8 hours and let it reset itself to see if problem persists.
Aug 26, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Xerox 8500 had power surge now it will not reset itself
You will need to reset the Xerox using the reset function (look under the diagnostics menu).
MJ Krier
Kriers Computing
Dec 03, 2008 | Xerox Phaser 8500/DN Printer
Sansa e 260 problem
I was charging my Sansa and then I look down at it and it was on a blank screen. Now it won't turn on. The computer says that the equipment has malfunctioned. I can not get to do anything at all. It was working fine, all I did was put it on charge. Can anyone out there help me with this problem. Has anyone out there seen this same problem with their unit?
Aug 17, 2007 | SanDisk Sansa e260 MP3 Player
HP Pavilion dv6000z Notebook Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
