Question about Acer Aspire 5500 5570-2609 Laptop
I have a acer aspire 5000 and when i turn it on it says bootmgr is compressed, press ctl+alt+del to restart but it wont restart
  • Acer Master
  • 27,725 Answers
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Posted on Jan 05, 2013
  • 17 Answers
SOURCE: bootmgr is compressed
I know of three solutions, none of them will work without recovery or OS discs, and I can only guarantee one of them--the one that whipes your system. Try these in this order (assuming you have system discs);
#1 Boot from the system disc and choose the "repair" option. This is the quickest fix, and you lose anything.
#2 Boot from the system disc, and in your Start menu search type "Command Prompt". Open Command Prompt and type (hit enter after each line);
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
#3 Run a full system recovery from your system discs.
Now, if you don't have your system discs, and you're running Windows Vista, there is another possible option. If your computer is fairly new then you probably have a WinRE partition for recovery, (a "factory image" drive)? I won't go into this now, if you have your discs option 1 or 2 should work for you.
Posted on Feb 27, 2009
fraywing
  • 37 Answers
SOURCE: cannot restart laptop
"Boot with the Vista DVD, when it enters Setup hit your SHIFT-F10 keys Setup will run "cmd", and drops you to a command prompt that is running with SYSTEM privileges.
Then at the command prompt type the following (hitting <enter>) after each line.:
del bootmgr
ren temp bootmgr
hope this helps! :)
cite: http://www.cybertechhelp.com/forums/showthread.php?t=151686
Posted on May 30, 2009
  • 3 Answers
SOURCE: laptop help
sounds like something got hosed up......use the recovery partition and reload windows....easiest thing to do....Good luck...
Posted on Jan 15, 2010
fix4issues
  • 95 Answers
SOURCE: My acer Aspire One is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your Windows Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.
If you don't have one, you can create a Windows Vista repair disk follow the steps,you can do that by using NERO or IMAGEburn,then click on browse for a file buttom and select the file
Put a blank cd in the drive and then click the write button
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 0b47d2b.png
now you have recovery cd.
HOW TO RUN REPAIR
BOOT FROM WINDOWS VISTA DVD
YOU CAN SELECT REPAIR FROM THE LIST ON THE LEFT
IT WILL TRY TO FIND INSTALLATION DVD DIRECTORY,IF THERE IS MORE THAN ONE SELECT THE CORRECT ONE AND PRESS THE NEXT BUTTON
CLICK ON THE FIRST OPTION START REPAIR
IT WILL START REPAIRING AND AT THE END YOU WILL BE GETTING PROMPT TO RESTART THE COMPUTER
ALTERNATIVELY YOU COULD CHOOSE COMMAND PROMPT WRITE bootrec /fixboot
ONCE YOU WILL SEE :The operation completed successfully type exit and press enter take out the cd and restart the computer.
ENJOY! EVERYTHING WILL BE WORKING OK
Posted on Sep 24, 2010
  • 3940 Answers
SOURCE: acer aspire 4736z with window
Boot to the Windows Recovery Environment (WINRE) for 7 and run the following commands from the command prompt:
c:
cd \windows
cd system32
compact /u c:\
compact /u c:\*.*
x:
bootrec /FixMbr
bootrec /fixboot
bootrec /rebuildbcd
exit
This will resolve the issue as the boot loader will no longer be flagged to be compressed, will uncompressed, and then rebuilt.
Posted on Mar 21, 2011
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
Apr 14, 2013 | Acer Aspire One D257 Netbook
Solusi untuk BOOTMGR is missing pada acer aspire one happy2 N578Q
This sounds like a hard drive failure, try your recovery disc if available, if no change! have the hardware checked for possible replacement.
Oct 26, 2012 | Computers & Internet
Bootmgr missing
that is important file for the boot process and since it's missing you will need to reinstall the operating system.
Mar 11, 2012 | Acer Aspire One Netbook AO531h-1729 10.1...
Getting message bootmgr missing press ctl alt del, but when i do this nothing happens
try this.. reboot your computer, or hold down the power button to shut it off then turn it back on, at the acer splash screen hit f2 to enter into setup. hit f9, load setup defaults and exit. it will reboot your computer and should let you in.
Oct 10, 2010 | Acer Aspire 5536-5224 Notebook
Bootmgr is missing. Press ctl-alt- del to restart. This message comes on screen when turned on and computer does not boot up.
Hi, go to this link, it gives clear easy instructions on solving this problem: http://cyberst0rm.blogspot.com/2007/04/how-to-fix-bootmgr-is-missing-in.html
Hope this helps
Jul 17, 2010 | Everex StepNote VA4103M Notebook
Laptop help
Jan 12, 2010 | Acer Aspire 5315 Notebook
Bootmgr is compressed and press ctri+alt+del to restart
Hello ajay1 8 83
You need run SFC /SCANNOW
Read this first for more understanding http://support.microsoft.com/kb/936212/
Try booting to your Vista installation CD. Choose Repair. Select your operating system, should bethe only one. It will repair the BOOTMGR.
Jul 12, 2009 | Microsoft Windows XP Media Center Edition...
Cannot restart laptop
del bootmgr
ren temp bootmgr
hope this helps! :)
May 30, 2009 | Acer Aspire 5500 5570-2609 Laptop
Presario c751nr bootmgr missing
Have them load whatever OS you lost to them, if you have the OS cd, try installing it yourself.
Dec 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
