I need to use 10 gallons to have the washing machine run. If I want to reduce to 7 gallons What shall I do.(the machine is heavy duty one) Best regards, olive
    Sergeant:
    Champion:
  • 318 Answers
The only way to use less water in a washing machine is to turn your settings down to medium or small load, this is false economy as it takes more loads of laundry to get the job done,,To use your washer to its full economy, do full loads of laundry.
The washer requires a set amount of water to run,any less and you are not going to be happy with the results.
If you have the financial resources, you can install a water reclamation system,this will save and filter and then re-use the water again and again.
Posted on Jan 19, 2009
How much coolant is needed for a full fill on a 2001 Expedition 5.4L
7 gallons of 50/50 mix anti-freeze with heavy duty radiator and rear heat, 6 gallons without rear heat and heavy duty radiator.
Nov 16, 2010 | 1998 Ford Expedition
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
MAF18-MC4VS heavy duty laundry machine
You cannot. There is a pressure switch that measures the weight of the water before moving on to the next cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 19, 2009 | Washing Machines
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Ge washing machine, trying to find out if model is a heavy duty washer model #WJSR2070B2WW serial # HF193930G
My solution was, I didn't want to pay $14.99 just to find out if the machine was a heavy duty washing machine. That's why I quit.
Oct 08, 2008 | GE Washing Machines
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
