Question about Frigidaire Ovens
How do I calibrate my Frigidaire (Model FEF352DWA) oven?
3 Suggested Answers
  • 58 Answers
SOURCE: OVEN WILL NOT COME UP TO TEMPERATURE
Yes there is something you can do. you can close the gap in temp by + or - 30degress by pressing and holding the bake button the display will change to 0 and now you can press up or down to what you want to calibrate it to. when set press start. now it's set. If your temp wonders off again you will have to replace the temp sensor. NOTE: SOME MODELS ARE DIFFERENT IN CHANGING THE CALIBRATION REFER TO THE OWNERS MANUAL IF THIS DOESN'T CHANGE YOUR CAL-SETTING
Posted on Jan 09, 2009
fixyourboard
  • 310 Answers
SOURCE: I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
Posted on Oct 14, 2009
Calibrate oven control
There should be a little screw on your oven control back of the control handle which you pull the handle off to get to it. Don't turn very much but you will need a thermometer to check the heat degrees when you do this.
Mar 20, 2015 | Frigidaire Ovens
My oven temp is not keeping correct temps set at 350 and acutual temp cooks at 325?? problem correction?
Hey friend, I appreciate your post!
It sounds like your Frigidaire oven could need to be calibrated. If could also be an issue with you thermostat or control panel. In order to properly calibrate your oven you would need to seek assistance from a professional. I would also recommend seeking assistance from a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Oct 04, 2014 | Frigidaire Ovens
Oven need calibrating
I am not sure, you can do this, I think you talk about Fahrenheit, which is about 2.2 Celsius, in the oven basically it is not making any different.
Mar 15, 2013 | Frigidaire FGB24T3EC Gas Double Oven
Wall oven is not baking properly
Look in your Owner's Guide to see if the unit you own has a way to configure or calibrate the temperature yourself before contacting a professional.
Jul 18, 2012 | Frigidaire Ovens
CANNOT FIGURE OUT HOW TO CALIBRATE THE OVEN. OVEN TEMPERATURE IS OFF 50 DEGREES. INSTALLED A NEW THERMACOUPLE. THIS DID NOT HELP THE PEOBLEM. OVEN WAS PURCHASED IN 1992. THANK YOU FOR YOUR HELP.
Without the Model Number I can only give you Basic instruction.
If your machine is Digital the best way to calibrate if find the manuel of your machine useing your Model number.
Some of the digital models : select bake and press and hold the up or down Temp button for 5 Sec to enter the calibration mode.
Some models require you do get the temp to over 400 deg befor you can enter the Calibration mode.
If your machine has a turn knob ... Take the knob off and see if there is a small screw in the center... This is the calibration screw.
Oct 05, 2010 | Magic Chef 9122 Gas Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How to calibrate double wall frigidaire ovens. temperatures are not true to digital control.
plaese post model number to assist you further. directions for calibration should be in user manual..
Feb 21, 2009 | Frigidaire 27 in. Electric Double...
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
23 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
