Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell proheat 1699-y
The steamcleaner will work but it won't spray out the water jets are not working what is the problem ?
    President:
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the
heater inside the handle asm. Make sure that where the tubes hook up
to it are not clogged. If water doesn't squirt, check for the seal at
the bottom of the tank, it needs to be on the tank, not in the hole.
The flow indictor cap is leaking air or maybe is too tight. If you had
the top cover off, make sure that the tubes are routed right so as not
to get pinched when the cover is put back on, the smart mix knob should
be in the water setting and that the piston is on the bottom of the
smart mix know. Pump is bad.
Posted on Jan 17, 2008
SOURCE:
My bissel proheat will work fine with the attachment hose but water will not come out of the bottom for carpet cleaning!
Hey Christy. I'm sorry you're having difficulty with the spray. I know how frustrating this must be.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Apr 14, 2013 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat 1699 won't spray from main/min. suction
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kgj
Jul 27, 2010 | Bissell 1699 ProHeat Clear View Upright...
No water is spraying out of my bissell proheat......
heatman101
tuio
Jun 22, 2010 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Proheat Clearview is not spraying water nor taking
heatman101
wrthrw
Apr 25, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water/chemical not releasing
heatman101
op
Oct 21, 2009 | Bissell 1699 ProHeat Clear View Upright...
Won"t dispense water
heatman101
ytoi
Mar 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Have a bissil proheat clearview plus model 1699-1,there is no water flow. soap seems to work. It was used one time but the system was not flushed. Has not worked since.
if you have spray through your hose and no spray on your carpet then your heater will be clogged with soap. try this and post later if thats not it.
Sep 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Clearview water problem
The water comes out the hose at the same time. The diverter only diverts the suction from floor to attachment. If it is constantly spraying there is a problem with the attachment. Is it not spraying on the floor?
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
211 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
