Question about Ruud UAMB Air Conditioner
Ruud heating problem (clicking)
When my heating unit goes off it continues to click for several seconds (minutes) afterwards. What could be causing this?
    Sergeant:
    Champion:
  • 318 Answers
Hi,,this is normal for any heater,,some are more audible than others ,,as metal parts heat up they expand,,and as they cool they contract,,what you hear is the metal expanding and contracting.
Completely normal, no worries.
Posted on Jan 19, 2009
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Feb 11, 2012 | Ruud Heating & Cooling
Switch heating on, hear a click that we normally hear then boiler fires up. Then goes off after about 30 seconds. Then won't come back on, though we still hear the click. Wait a while before trying...
could be a number of things, it could be cycling on the high limit switch, (lack of water flow, or pump) this would be my guess if you are not resetting power and the unit is trying to restart. It also could be the flame sensor not proving ignition. hope this helps!
Dan
Mar 12, 2010 | Ruud UBHC Air Conditioner
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
Heat pump clicking continuously; lights blinking
I had the same experience. I finally found someone who knew what was wrong. There is a relay switch that is attached to the defrost board. Apparently this is a common problen with RUUD. I had the board replaced and it took care of the problem. It was about $80 for the board and $80 for the service call. Hope this helps.
Dec 28, 2008 | Heating & Cooling
Ruud heat pump makes a clicking sound
Many thermostats have a setting to keep the fan running instead of cycling with the compressor. Check its settings.
Dec 21, 2008 | Ruud UBHC Air Conditioner
Outside unit clicks while thermostat auxiliary light flashes
Sounds like the compressor starting relay or capacitor is defective. When the compressor could not start, the electric heat came on to satisfy the heat requirement and causing the emergency heat light to come on at the thermostat. This light warns you that electric heaters are energized. And they use a LOT of electricity! Call a different company for service. And do it soon.
Ray
Nov 16, 2008 | Ruud Handler Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Fan keep,s blowing
Your thermostat is calling for blower, your fan relay is stuck, or that model had a time delay blower solid state board on it which had the blower relay on it, and it could be bad. I would turn the power off to all of your system for a few minutes and see if this could make something happen.
Nov 20, 2007 | Heating & Cooling
Ruud UAMB Air Conditioner Logo
79 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
